Go to Post This, right here, is why I participate in FRC. Changing lives, one corndog at a time. - Jared Russell [more]
Unread 10-02-2015, 00:17
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Nick.kremer is an unknown quantity at this point
Team 3512 Sneak Peek
Footage from the initial day of testing our 2015 bot, Talos:
http://youtu.be/-vis0qLjtvs
I wish I had captured more video of it! Maybe tomorrow.
Check out Team 3512's Website!
Like us on Facebook!
Unread 10-02-2015, 01:38
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Team 3512 Sneak Peek
Looks speedy! If you guys have a second robot, some good programming could turn it into a real demon.
Unread 10-02-2015, 01:49
Thanks!
Only built the one bot unfortunately! But we have another week of software to test with lots of encoders and limit switches to implement so hopefully it'll be much faster and smoother by stop build day.
Unread 10-02-2015, 14:25
KPSch KPSch is offline
AKA: Ken Schenke
FRC #1987 (Broncobots)
KPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to all
Very fast elevator! I noticed the motor back-drives. Does your team have a solution for it?
Unread 10-02-2015, 14:50
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
What motors/gearbox are you using to drive the lift?
Sleep? What is that? A rare Pokemon?
Unread 10-02-2015, 17:26
Mechanically no, but we are planning to do this in software.
Also, it doesn't drop that dramatically under normal conditions, but in the video, the programming team disabled the robot a second after it starts lifting which is why it drops suddenly.
Unread 10-02-2015, 17:32
We are running an AndyMark Super Shifter 30.1:1 (not utilizing the high gear) with 2 CIM motors. On the output shaft of the gear box is a 48 tooth sprocket which is connected by #35 chain to a 26 tooth sprocket at the top of lift.
