Go to Post Of course this should be your decision- not the FIRST community's. Take charge of your destiny. - Wayne C. [more]
Unread 02-10-2015, 05:26 PM
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
arichman1257 is on a distinguished road
Check if piston is extended
Is there a way to do this? if so please explain as best you can. Thank you
Unread 02-10-2015, 05:47 PM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Check if piston is extended
You could place a limit switch such that it triggers when fully extended. Alternatively, you could get a cylinder with the magnetic option and utilize a magnetic reed switch on the cylinder itself to read the position when either extended or retracted. Basically, the reed switch straps to the side of the cylinder beer the top or bottom, and when a magnet inside the cylinder reaches it, it closes a contact that can be sensed through a digital input just like a limit switch.
2016: Lake Superior WFFA
