Go to Post I have no defined complaints, and I have no solution. I simply have mixed feelings. - Andrew Blair [more]
Unread 02-10-2015, 05:49 PM
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Need assistance with setting up a pid output.
Hey, I finally got my pid loop to work. Only one problem, when I use the button I've set to st the motors to the output, they go to the output at the time they were pressed, but this doesn't change unless I press the button once more. I.e if the motor would go full speed as it was X distance from the goal, it would go full speed until I press the button again, it would then go th speed it needs to BASED ON THE TIME it was once again pushed. Here is the output code
(Using a tablet. Sorry if this comes out slightly off)
if (stick>GetRawButton(9))
{Motor>Set(output);
This is using iterative robot BTW.
Unread 02-10-2015, 08:38 PM
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Arrowhead is an unknown quantity at this point
Re: Need assistance with setting up a pid output.
The problem is that you are only setting a new value to the motor whenever you press the button, when you don't have the button pressed it just continues on with whatever input it had last. You should probably have the motor speed continuously updated if you are using it with a PID loop.
