Go to Post Gracious Professionalism at its finest - Competing like CRAZY on the field, then working together like professionals off the field to make these events the best they can be for everyone involved. - Stu Bloom [more]
Unread 10-02-2015, 20:42
ericalbers ericalbers is offline
ericalbers is an unknown quantity at this point
How do you get interrupt when digital input is set
Is there code showing how to get a interrupt when say a limit switch is hit?
I see the
public abstract class InterruptHandlerFunction<T>
is there example code of how to implement this for the requestInterrupts off DigitalInputs?
I'm having trouble with how to define the polymorphism of the function properly.
Thanks
Unread 10-02-2015, 20:52
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: How do you get interrupt when digital input is set
This is how I used interrupt handlers in a gyro driver. The really wierd part about it is that the interruptFired() method is package private, so any class that uses it needs to be in the edu.wpi.first.wpilibj package. I think this was an oversight on the part of the authors of WPILib.
DigitalInput interrupt = new DigitalInput(0);
// Register an interrupt handler
interrupt.requestInterrupts(new InterruptHandlerFunction<Object>() {
     @Override
     public void interruptFired(int interruptAssertedMask, Object param) {
          // Do stuff
// Listen for a falling edge
interrupt.setUpSourceEdge(false, true);
// Enable digital interrupt pin
interrupt.enableInterrupts();
Unread 10-02-2015, 20:55
Thanks, actually the private part is what was reallly killing me, I just could not get the thing to be happy I had the same code...
testinput =new DigitalInput(0);
testinput.requestInterrupts(new InterruptHandlerFunction<Object>()
@Override
I just couldn't get it to like the interruptFired no matter how I set it up...the base class having an error explains it though
Thanks
Unread 11-02-2015, 17:06
How much code do you plan to put into the interrupt routine?
