Go to Post But you are right about one thing, it is downright un-American. The Triplets are Canadian. - rourke [more]
Unread 10-02-2015, 20:56
Re: Can't Connect to roboRIO or DLink
Nothing you describe matches anything I can think of. Do you know any other teams in the St. Louis area that might be able to help you in person with some basic troubleshooting? There could be something obvious that you don't know to look for or to tell us about.
Unread 10-02-2015, 20:58
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
Just ran into this problem myself, or at least I think I did.
I solved it by changing my IPV 4 to 10.xx.yy.3 (xx and yy being team number) and was able to connect immediately. Don't know if it will work but worth a try at least.
I kind of know programming
Unread 11-02-2015, 00:40
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Check the lights on the RoboRIO after it starts up, and compare with the status light info on this page to make sure the issue is not with the controller:
http://wpilib.screenstepslive.com/s/...uick-reference
When we first setting up our controller it exhibited similar behavior, it turns out it was because we hadn't properly image the RoboRIO when we thought we had. The Status and Comm lights should help narrow down the issue.
