Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
Unread 10-02-2015, 19:42
JohnFogarty's Avatar
AKA: @doctorfogarty
PCM Solenoid Current Output
I've done some limited searching and for some reason I can't measure it right now, but I need to know what the current output is on the PCM Solenoid outputs. Can anyone help me?
John Fogarty
Unread 10-02-2015, 20:23
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: PCM Solenoid Current Output
Please read 1.2 Electrical Specifications in PCM User's guide. The total current is rated (sum of all channels).
Why do you need to know this?
Unread 10-02-2015, 20:47
AKA: @doctorfogarty
I am attempting to use this http://www.mcmaster.com/#6425k11/=vusltm as part of our Pneumatic system. When wired to the robot the solenoid does not function. The solenoid uses a input of 24V & 0.15A. 3.5 Watts.
We are using 3 of them which if I'm not mistaken would mean a total current draw of 0.45A ~ 450mA
John Fogarty
Unread 10-02-2015, 21:45
ozrien's Avatar
Omar Zrien
AKA: Omar
That math seems right. What is the measured voltage across the solenoid signal? Is it 24V? Is the PCM solenoid channel's LEDs illuminated red?
If the current demand is close, you might need a supplemental PCM.
Unread 10-02-2015, 22:08
AKA: @doctorfogarty
I found out the problem was on the connector of the solenoid. They use similar screw terminals to what is used on the power connector for the robo-RIO. A wire was not in the correct position in the connector.
All 3 of them are working now.
All is well. I'll keep in mind we might need another PCM if we use more solenoids. However I don't see that becoming a problem.
John Fogarty
Unread 10-02-2015, 22:44
ozrien's Avatar
Omar Zrien
AKA: Omar
I would still measure the solenoid voltage, or better yet just use the Self-Test while all the solenoid outputs are enabled and see if the 24V rail dips at all. Should be a quick test, just nav to the roboRIO webpage and press Self-Test after selecting the PCM. If the voltage rail doesn't dip as a result of turning them on then you should be good to go.
Self-Test button is explained here...
http://wpilib.screenstepslive.com/s/...ribution-panel
Unread 10-02-2015, 22:51
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
If the current draw was a problem, would it help to turn off the PCM output after actuating the solenoid (assuming it's a double solenoid and nothing will return on you when cutting voltage)?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 10-02-2015, 23:51
AKA: @doctorfogarty
Will do the test first thing tomorrow.
Also we are using spring return single solenoid as shown in the link above.
John Fogarty
