Go to Post Quoting Fred Durst--"Bring it on." - Billfred [more]
Unread 11-02-2015, 08:36
popcorn107 popcorn107 is offline
FRC #2386
popcorn107 is an unknown quantity at this point
Suddenly cant push to roborio
Last night we attempted loading new code to our roborio. The night before we could push fine but now we keep getting told that no process in pidfile found. We tried re imaging the roborio and installing java again and the message persists. I have also updated all software after we got started getting this. The program is building sucsefully and locating the roborio on the network. We get two different errors normally.
Here are the two different build logs:
Buildfile: C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\build
   [delete] Deleting directory C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\dist
compile:
    [mkdir] Created dir: C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\Brian/wpilib/java/current/lib/WPILib.jar:C:\Users\Brian/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 1 source file to C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\dist
    [mkdir] Created dir: C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\build\jars
     [echo] [athena-jar] Copying jars from C:\Users\Brian/wpilib/java/current/lib/WPILib.jar:C:\Users\Brian/wpilib/java/current/lib/NetworkTables.jar to build/jars.
     [copy] Copying 2 files to C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\build\jars
      [jar] Building jar: C:\Users\Brian\Documents\Central Schoolwork\Robotics\frc 2015\programming\Teleop\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-2386.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to roboRIO-2386.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-2386.local:22
      [scp] done.
  [sshexec] cmd : killall netconsole-host
  [sshexec] killall: netconsole-host: no process killed
  [sshexec] Remote command failed with exit status 1
      [scp] done.
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] no process in pidfile '/var/run/natinst/FRC_UserProgram.pid' found; none killed
BUILD SUCCESSFUL
Total time: 17 seconds
and:
clean:
compile:
jar:
get-target-ip:
dependencies:
deploy:
      [scp] done.
      [scp] done.
      [scp] done.
  [sshexec] start-stop-daemon: warning: killing process 1795: No such process
BUILD SUCCESSFUL
Total time: 15 seconds
Unread 11-02-2015, 08:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Suddenly cant push to roborio
There's probably a simpler solution, but we had that about a week ago, and after an hour or two of futzing with it we decided to re-image the 'RIO.
Unread 11-02-2015, 08:45
FRC #2386
This was one of the first things we attempted. We re imaged the rio and put java on it again and still get these error messages.
Unread 11-02-2015, 09:02
Jared's Avatar
Jared Jared is offline
Both logs show a successful upload.
During the upload process, the roboRIO attempts to stop the previous version of the robot code, but it fails to do so. This may be because your code is crashing or there is an exception that causes the user program to stop running. This may also be because you have just reimaged the roborio and there is no code running yet.
Unread 11-02-2015, 09:39
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Not sure what we did but we are now able to push our code to the robot.
Unread 11-02-2015, 10:53
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Those errors are normal and can be safely ignored, that is probably why you found that you could deploy code again.
Unread 11-02-2015, 13:47
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
We spent a fair amount of time trying to resolve this issue. Re-imaging may fix it for some but I don't think the issue is on the roboRIO, it's on the IDE side. When we synced our code to another machine it deployed fine.
Last night we discovered that it happens every time we try to deploy code the first time after running in debug. Deleting the bin, build, and dist directories for the project resolved the issue.
2015 Newton Semi-Finalist (3130, 2468, 3310, 537)
2015 Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360)
2014 Colorado Regional Winner (1138, 3310, 2543)
2013 Texas Robot Roundup Winner (3310, 624, 2848)
2013 Archimedes Semi-Finalist (126, 3310, 1756)
2013 Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
Unread 11-02-2015, 16:06
Jared's Avatar
Originally Posted by Brian Selle View Post
This isn't an error!
If it says build successful, it's worked.
This simply means that it can't find a normal running robot program to kill during the deploy process. It makes perfect sense because you were previously running a debug program, which is different.
Unread 20-02-2015, 15:45
Never said it was an error, but you are correct it is not an error. The first time this appeared we were unable to deploy code to the roboRIO but it was coupled with another issue. Removing the files simply makes the message go away.
