| View Poll Results: What will your robot be able to do? | |||
| Autonomous: Stack 3 totes |
58 | 47.93% |
| Autonomous: push a single item into Auto Zone |
71 | 58.68% |
| Autonomous: Push multiple items into Auto Zone |
59 | 48.76% |
| Autonomous: Grab 1 recycling container from step |
27 | 22.31% |
| Autonomous: Grab more than 1 RC from step |
35 | 28.93% |
| Autonomous: Pick up Gray Totes |
24 | 19.83% |
| Coopertition: Put a tote on the step |
81 | 66.94% |
| Coopertition: Stack two or more on the step |
99 | 81.82% |
| Cooperitition: Stack one a tote on top of another tote |
80 | 66.12% |
| Teleop: Load quickly from feeder station |
67 | 55.37% |
| Teleop: Make stacks 4+ tall (no RC) |
77 | 63.64% |
| Teleop: Make stacks 4+ tall w/RC |
96 | 79.34% |
| Teleop: Top established 4+ stack w/RC |
57 | 47.11% |
| Teleop: Top established 6 stack w/RC |
31 | 25.62% |
| Teleop: Load quickly from ground (i.e. landfill) |
83 | 68.60% |
| Teleop: Stack upside-down totes |
17 | 14.05% |
| Teleop: Pick-up and stack tipped RC's. |
63 | 52.07% |
| Score more than 30 teleop points individiually (no coopertition) |
53 | 43.80% |
| Score more than 50 teleop points individually |
60 | 49.59% |
| Score more than 70 teleop points individually |
43 | 35.54% |
| Score more than 90 teleop points individually |
33 | 27.27% |
| Sweep pool noodles into landfill |
29 | 23.97% |
| Pick up pool noodles from ground and put into RC |
3 | 2.48% |
| Multiple Choice Poll. Voters: 121. You may not vote on this poll | |||
Robot Capabilities?
There is a lot of talk about what robots should be able to do and how to accomplish different tasks, but what things will your robot (likely) be able to do in your first competition? Mark all that apply.
Re: Robot Capabilities?
Our robot can:
>Pick up a single tote! (Because this list has to start somewhere.) >Pick up a single bin! (At least, we'll probably be able to do this reliably in a day or two.) >Place a single tote on top of a stack of 1-2 existing totes! (We could have made it capable of placing a bin on top of a larger stack, but we decided it wasn't worth it) >Place a bin on top of a tote! (Again, probably a day or two before this happens.) >Make a stack of up to six totes and a bin! (This is the Big Kahuna right here.) >Pick up a stack, add to it from the bottom, and drop it off again! (This will probably come in handy too.) We're working on autonomous right now, and hoping to get a 2-3 tote auto before Bag & Tag. ~~~ [Edit: Should this be a poll?] [Edit edit: Poll added! Thanks!] Last edited by Thromgord : 11-02-2015 at 11:48. |
>Make a stack of about 4-5 totes
>Lock them into place when they're on our bot >Hopefully with a bin+noodle combo >Drive into the auto zone during autonomous >Do a barrel roll (soon...) |
>Frustrate Cadders and Programmers
>Cut engineers with blunt surfaces >Move on its own The usual 4-5 tote capacity can do bins and strafes |
I expect a stack of 3 totes in autonomous to be fairly rare, so the claim by close to half of the respondents that they will be able to do a 3 tote stack seems somewhat overconfident.
In 15 seconds you have to pick up a tote, move, pick up a tote, move, pick up a tote and then move to the autonomous zone, set them down and move away so you aren't supporting them. That's a tall order. The video posted this morning of a bot picking up a tote and container then moving to the auton zone took 12+ seconds and that didn't require much movement or autonomous alignment. |
* Have a strong intake system * Internal stacking * Load totes the long way * Have a strong, fast lifter * Have a way to push recycling containers out of the way ... it isn't that hard. We designed our robot with the the autonomous stack in mind and specifically made several design choices so that we would have the capability.... I am pretty darn certain that our robot has the capability of doing it pretty easily - the only question is whether or not we have given our programming team enough time to get it (and a million other things) running before our week two competition.... If we can do it, so can many other teams... Strong autonomous routines are a focus of many teams..... The real question to me is: How many robots will have an autonomous routine allowing them to stack all three totes *and* drag the three recycling containers into the auto-zone for a 28 point autonomous? ![]() |
#7
I also don't think it's so much capability as time that will be the limiting factor. I suspect that if autonomous were 20 seconds there would be plenty of teams that could get 3 totes. At 15 seconds I expect a lot of "darn that was almost there." |
#9
Current capabilities:
Six tote stack with RC coopertition stack take RC off of step Wide and narrow tote intake/elevator Clear landfill zone of totes Robot auto set Tote chute receiving Capabilities in progress: 3 tote stack auto set Tote auto set Landfill clearing/RC grab autonomous |
#10
These are either a misrepresentative sample, skewed by very good team, or their are some very optimistic people out there, or we have seriously under achieved with our robot.
We can: -Make stacks of 4+ totes -Load from the chute -Pick up other totes that are right side up We are working on: -Autonomous (Moving an RC and tote) We have a withholding allowance: -To get a RC lift working (up to 5 totes) |
#11
The least surprising statistic from this poll is that no one has chosen to pick-up pool noodles and place them in Recycling Bins.
sarcasm I wonder why? /sarcasm |
#12
Grab two containers off the step in auto and also stack yellow totes
Carry two countainers around at the same time and stack both in two stack parellel to each tour simotsiniously Stack gray tops however highs we need |
#14
Our robot can;
Stack ~4+ totes & potentially a RC w/ litter on top. Auto Collect 2 Recycling Containers from the step. Keeping them upright. Co-op stack place up to 3 totes on step. Auto 3 tote, 1 RC, 3 totes & 3 RC. Primarily load from chute. |
#15
OK, I'm trying to figure out this bit from the poll results:
