Go to Post This game is all about dealing with the unexpected and making changes on the fly. - Greg Hainsworth [more]
Unread 11-02-2015, 13:47
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Completely lost about Pneumatics
Originally Posted by brianaong View Post
We want to be able to control how much air is released from the cylinders because the arms, in theory, should adjust to the width of both of the bins and all sides of the totes.
If I'm reading this correctly, this is one of the few cases where it is easy to get pneumatic cylinders to stop halfway.
Just dump all of the air on the other side - if the tote is between the arms of the cylinders, and unless the cylinders can exert enough force to deform or brake the totes, the arms will stop shortly after meeting the ends of the tote, and hold it with a steady pressure. The grabber is "self-adjusting".
