Go to Post The best way to get to Einstein is to analyze the game, figure out which three robots would make up the ideal Einstein alliance, and then design, build, iterate, and polish the one that best matches your teams' capabilities. - Jared Russell [more]
Unread 11-02-2015, 14:22
gwin99 gwin99 is offline
FRC #0751
gwin99 is infamous around these parts
Re: Braking
Originally Posted by Andrew Lawrence View Post
If you gear your elevator correctly, you should have no problems relying on stalling the motors for short periods of time. I wouldn't see any need for you stall your motors for extended periods of time great enough to cause any negative effects.
Can you describe the power transmission system for your elevator (motors, gearing, etc)? I'd be more than happy to help get your system so that you can safely run at stall, which would save both weight and possibly time.
Currently we have a mini cim through a versa planetary 5:1 driving a 3" winch. We also bought a 3:1 stage and will add it (for 15:1) if we aren't getting enough torque.
