Go to Post Don’t get caught in mindsets which will limit the potential that the future may hold. - Jaine Perotti [more]
Unread 11-02-2015, 16:45
eaglesapex5310's Avatar
eaglesapex5310 eaglesapex5310 is offline
Eagles Apex Team 5310
AKA: Barbara Froehlich
FRC #5310 (Eagles Apex)
eaglesapex5310 is an unknown quantity at this point
Program Help
When sending the robot's code to the RoboRIO, when you right click the program, do you click on "Deploy" or "Run as startup"?
Unread 11-02-2015, 16:50
BL0X3R BL0X3R is offline
AKA: Nick
FRC #4488 (ShockWave)
BL0X3R is on a distinguished road
Re: Program Help
Which programming language are you using?
Carson Finalists (4488, 67, 225, 5659)
2x District Winner + Gracious Professionalism & Engineering Excellence, DCMP Finalist and Entrepreneurship
Galileo Finalists (1153, 4488, 1318, 1218)
2x District Winner + Chairman's & Industrial Design, DCMP Finalist and Quality Award
http://www.chiefdelphi.com/forums/image.php?type=sigpic&userid=74752&dateline=139804  7731 Oregon Rookie All Star, Curie Rookie All Star
Unread 11-02-2015, 16:57
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Program Help
In LabVIEW, you want to choose "build" under "Build Options." Once it's done, use "Run as Startup" from Build Options to send it to the robot.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 11-02-2015, 18:27
Re: Program Help
"Deploy" will typically work unless you've done something unusual to the roboRIO configuration, but there's really no reason ever to use it. "Run as startup" is the correct action.
