Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
Unread 11-02-2015, 16:40
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
RoboRIO not getting power.
We have pretty much the worst possible problem at this stage in the build. The RoboRIO isn't getting power and we cannot figure out why. The wires are securely connected to the Power Board and to the RoboRIO and EVERYTHING on the bot is lighting up (indicating power) except the RoboRIO. We've tried reconnecting the wires and at this point the only thing that I can think could be wrong is that the RoboRIO is shorted. If that is what has happened then we are pretty royally f***ed. Please someone try to help me out and find what the problem is because I'll probably go insane if this is shorted.
Unread 11-02-2015, 16:47
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: RoboRIO not getting power.
Did you install the little fuse on the PDP next to the roboRIO power connector?
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Could you have blown the small fuse on the PDP that protects the RoboRio circuit?
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 11-02-2015, 16:50
Yes we installed the little fuse
Unread 11-02-2015, 16:52
How could we tell if we blew the small fuse on the PDP?
Unread 11-02-2015, 16:57
You can pull the fuse and look at it.
Or, you can remove the power wires from the roboRio and use a volt meter to make sure you are getting 12 volts (careful not to accidentally short the wires, or you will blow the fuse).
Make sure you check your polarity. I think the roboRIO has circuits to prevent blowing the roboRIO if you have reverse polarity.
If:
1) You have 12 volts on the wires
2) You have long enough leads on the wires
3) You have proper polarity
4) Inserted the wires correctly
then you probably need a new roboRIO.
Unread 11-02-2015, 17:00
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
If you can post some pictures of your wiring from the power board to the roboRIO that would probably be helpful.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 11-02-2015, 17:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The first thing to check is to see if the voltage is coming out of the PDP on the port to the RoboRIO.
If not, the fuse next to the port is the first place to look.
If it is, check at the 'RIO end of the power cable to be sure you don't have a broken wire.
If you're getting voltage at the 'RIO input, but the lights aren't coming on, it's time to look at National Instruments documentation. If you can't find anything on this in a reasonable amount of time (an hour or two), contact them - the NI documentation and website are well known for being terrific at some things and terrible at others.
Unread 11-02-2015, 17:05
What exactly do you mean by the National Instruments Documentation?
Unread 11-02-2015, 17:23
https://decibel.ni.com/content/servl...r%20Manual.pdf
from here:
https://wpilib.screenstepslive.com/s...dware-overview
and this info:
https://decibel.ni.com/content/docs/DOC-40980
But, power is pretty fool proof. If you have power at the connector, and the polarity is correct, the roboRIO should light up. If it doesn't light up, there is not much you can do.
Unread 12-02-2015, 15:41
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Could the two wires coming from the PDP be reversed? Black to "C" and red to "V".
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 12-02-2015, 16:58
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Could you possibly have the insulation crimped on either the PDB or RoboRIO?
Nate
Unread 12-02-2015, 19:27
philso philso is offline
FRC #2587
Probe the two screws on the power connector of your RoboRio. You should be able to measure your battery voltage there if the wiring to that point is correct.
