I'm over the moon for you.
Unread 11-02-2015, 17:02
AMT103 encoder ground *WARNING*
The AMT103 encoder from CUI has a metal body. It is electrically connected to the ground pin on the connector. If the encoder is physically in contact with metal mounting hardware that connects to the robot frame, then there is continuity from the frame through the encoder to the negative terminal of the battery. If battery voltage is accidentally applied to the frame, something is probably going to burn.
In our case, that "something" was the ground wire in the ribbon cable between a Talon SRX and an encoder breakout board.
We have metal 10-32 bolts holding the am-0208 encoder mounts to the gearbox. We are currently in the process of replacing them with nylon bolts.
Unread 11-02-2015, 17:21
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: AMT103 encoder ground *WARNING*
Wow, that's good to know. I hope nothing else on your robot was damaged.
Unread 11-02-2015, 18:04
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Ugh...
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 11-02-2015, 18:42
jwhite jwhite is offline
FRC #2823
jwhite is an unknown quantity at this point
Very interesting; we may have burned a wire up because of this. We were accusing a student of being overly aggressive on the heat shrink, but this is a viable alternate theory. Hmm.
Unread 11-02-2015, 21:55
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
I'm glad we build wood robots...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 11-02-2015, 22:08
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Thanks for the heads up.
College sux yo
Unread 11-02-2015, 22:43
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Thanks ever so much for this information!!
I had the students go through the three AMT103 encoders on the robot and verify continuity to the frame and found one of the encoders was indeed shorting to the frame. It turned out to be the nut that is holding the mounting plate that we made was touching the encoder case. We just had to turn the nut to rectify it. We have added heat shrink to the nuts for now. We will be replacing the mounting hardware with Lexan instead of aluminum and as you suggested replace the steel bolts with nylon.
Again many thanks and good luck this year!!
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 11-02-2015, 23:39
FRC #2823
As a side note, our students have been destroying the clips and red sleeves on these encoders like they were popcorn. Be very careful manipulating the plastic tabs.
I've just discovered you can order replacements backs and sleeves for the encoders separately, which will hopefully help.
Unread 12-02-2015, 07:48
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Dido
One inexpensive solution I found to this is get the next size up sleeve and add gaffers tape, electrical tape or some other tape to the shaft until it is snug.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 12-02-2015, 08:54
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Are these encoders electrically isolated from the shaft? I'm reasonably confident that we can keep the case isolated...but I'm sure the shaft is going to be grounded to the frame through a bearing or something.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 12-02-2015, 09:20
A pair of plastic components isolates the shaft from the main body of the encoder, and I think the part they interface with is also plastic. I do not believe there is any risk of an accidental electrical connection that way.
We're using the "snow" (white) one for 1/4" (6.35 mm) shafts. Red sleeves are only 6 mm.
We determined almost immediately that the encoder bases are too fragile to reuse. Of the ten we started with, only two survived having the encoder removed without at least one of the three clips breaking. CUI pointed us to the "naked" encoder base in the Digi-Key catalog:
http://www.digikey.com/product-detai...322-ND/4835233
From that starting point, we found many individual parts that might come in handy. Digi-Key search URLs are not persistent, so I can't copy and paste here, but you should be able to navigate to Product Index > Sensors, Transducers > Accessories and choose CUI Inc from the Manufacturer list.
