Go to Post We can read about torque and speed in books, we can build a robot and drive it, but determination and character are built by time and encouragement, not just by studying. - Eugenia Gabrielov [more]
Unread 11-02-2015, 19:01
Minerbotics4827 Minerbotics4827 is offline
FRC #4827
Minerbotics4827 is an unknown quantity at this point
Re: Basic Limit Switch
I've figured out how to setup the normal limit switch, however, I am not sure on how to set it up so you can have a button override what the switch does when pressed. Someone helped us set up something similar last year at competition, but our old code got messed up.
Unread 12-02-2015, 23:10
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
The attached file is only meant to be suggestive, but would accomplish the task of an override.
It assumes a limit switch that is true if not, remove the not gate.
Basically an override boils down to the limit is not pressed or the override is.
Note: on the comment going to the motor, the value is otherwise zero.
Unread 17-02-2015, 18:42
FRC #4827
Thanks for replying everyone. We have it setup how we want now. We ended up going with two limit switches set as upper and lower limits with the in range and coerce function on labview.
