Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
Unread 11-02-2015, 19:12
Arbalest007 Arbalest007 is offline
FRC #2496
Arbalest007 is an unknown quantity at this point
How to Restart Autonomous Code in Driver Station?
Hi everyone. Is there a way to restart the autnomous code on the Driver station? Atm I'm reuploading code every time just to restart the autonomous even if I make no changes to the code and I was wondering if you guys have a solution for this. Thks!
Unread 11-02-2015, 19:15
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: How to Restart Autonomous Code in Driver Station?
Does disabling then re-enabling not work?
2014: IRI on a losing record.
FRC #2496
No, the code seems to just be paused when I disable the robot in Autonomous mode.
Unread 11-02-2015, 19:16
Volunteer, WPILib Contributor
no team (Waiting for 2021)
What language are you using? If using labview, it should be resetting every time. If using Java or C++, you might have to reset your state machines in Auton Init.
Team 4488 - Mentor 2013-2016
Unread 11-02-2015, 19:21
Darkseer54's Avatar
AKA: Zach Kaplan
If you switch to practice mode does that work? (Make sure to configure practice mode in setup first)
Unread 11-02-2015, 21:16
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
In the 2nd tab in driverstation, there is an option to restart the robot code. Have you tried that?
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 11-02-2015, 22:14
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Disabling and enabling should do the trick. There isn't a need to reset robot code. Try enabling tele-op then autonomous again. Weird that you have this problem.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 12-02-2015, 10:30
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Agreed. If you are using C++ or Java what is your robot base class: SampleRobot or IterativeRobot? If it is IterativeRobot you will definitely need to put some code in your AutonomousInit function to reset the state machine. If it is SampleRobot, then you need to reset the state machine at the top of the function (or at the bottom when it is exiting after being disabled).
