Go to Post Regardless of the next course of action, getting steamed and angry will benefit nobody. And coming from me, that has to mean something. - Lil' Lavery [more]
Unread 11-02-2015, 19:43
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Auto won't run
Can anyone tell me why my code won't work?
When I enable the robot, the motors output like they are supposed to for a half second, then seems to hang. The probes stop updating and the motors stop running. Can anyone tell me why this is?
2015 MAR District Champions
Unread 11-02-2015, 19:54
The ride never ends
Re: Auto won't run
Update: This is not specific to this auto mode, this is happening in all my auto modes.
Unread 11-02-2015, 20:06
The ride never ends
Re: Auto won't run
Update: I dropped a bit of sample code in the auto mode selector, and it worked perfectly, so it must be an issue with my code
Unread 11-02-2015, 21:32
Re: Auto won't run
Your drive motors are being commanded only once. Things will work better if you add a While around the drive code, with a Wait of 10 or 20 ms to keep the loop from eating up all the CPU time.
The Gyro Get Angle will have to be duplicated inside the loop for the 90 degree turn. (You can't communicate time-varying values into or out of a loop; they take their inputs once when the loop first begins, and produce an output once the loop finally finishes.)
Unread 11-02-2015, 22:12
RobotMonkey RobotMonkey is offline
FRC #1413
RobotMonkey is an unknown quantity at this point
Re: Auto won't run
The motor stopping is probably the safety config kicking in. I am guessing you enabled it in begin. You could either turn it off for auto, or make the the calls less than 100 ms apart.
Unread 12-02-2015, 12:46
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Re: Auto won't run
If you message me I will give you the code that we use for Auto. I think you will find that it is very straight forward and easy to use.
Unread 12-02-2015, 19:58
The ride never ends
Re: Auto won't run
Thank you so much, I did that and now the drive works perfectly!
I have another problem, if its not a bother:
After the pistons clamp, it doesn't move to the next part of the flat sequence structure. Can anyone spot the problem? I've been looking at it for the past hour.
Unread 12-02-2015, 21:25
Re: Auto won't run
Your "Turn 90 degrees" frame sets the drive state to 4, which I see is supposed to turn at 30% power. But then it immediately sets the state to 3 while it waits for the turn to complete. I assume drive state 3 just sits there doing nothing. Get rid of that extraneous 3 -> State3 underneath the gyro angle indicator in the while loop.
(I suggest that you move the frame labels from above the flat sequence to actually inside the frames they are labeling. That way they will stay connected to the code they are describing if you ever rearrange things.)
Unread 13-02-2015, 11:11
Programming Mentor
AKA: Tim Easterling
Re: Auto won't run
Here is the example code. Let me know if you have any questions.
Unread 13-02-2015, 11:16
Programming Mentor
AKA: Tim Easterling
Re: Auto won't run
How do I attach a zip file?
Unread 13-02-2015, 11:26
Programming Mentor
AKA: Tim Easterling
Re: Auto won't run
Another try at it.
