Go to Post you should be putting forth you best effort every time you enter the field. - Protronie [more]
Unread 11-02-2015, 20:41
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Re: Axis Camera Issue
We were having the exact same issue today and tried the exact same things that you did. I was able to access the camera via a web browser at the IP address, but was not able to get it to work on the dashboard. Just to make sure, did you guys try on the dashboard to select "IP Camera" in the dropdown next to the feed?
Also, can you please post a link to this guide? I was unable to find one when we were troubleshooting. Our's is still not working.
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
