Go to Post Downsides: it's highly toxic and recognized as a carcinogen in CA. Upsides: Basically everything else - lethc [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 11-02-2015, 21:12
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Re: Problem With Talon SRX Enabling
What program language are you using?
What happens if you start with 7 talons enabled and then add one at time and verify that they work?
I didn't see or understand, does using an ethernet cable behave the same as using the usb cable ?
Also, when you switch to wi-fi, make sure you have all the other network inter-faces disabled.
Also, do you have an another wi-fi network interfering with your wireless? You can use a network display tool to see how many wi-fi signals are around you.
