Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 11-02-2015, 20:44
Bewizardment Bewizardment is offline
Team Role: CAD
Bewizardment is an unknown quantity at this point
What do you use to control your robot?
Our drivers are trying to find a new controller to operate our robot. The standard dualshock just doesn't cut it anymore. Do you use a steering wheel? A custom designed board? Share your control schemes.
Unread 11-02-2015, 21:04
TheThings's Avatar
TheThings TheThings is offline
AKA: Becky Daniels
FRC #0930 (B.E.A.R.s)
Team Role: Scout
TheThings is an unknown quantity at this point
Re: What do you use to control your robot?
We use an Xbox controller, two actually.
Unread 11-02-2015, 21:06
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
We design a new control board each year, depending on driver preferences and control needs.
Typically, we use two joysticks for the driver. This year, we are giving our manipulator a Playstation or X-Box controller. The buttons on the joystick and controller will be used for various simple pre-programmed routines. We'll also have a series of buttons and switches on the control board that will be used for major commands and autonomous routines - buttons that would "disasterous" should they actually be pressed in error.... The drivers' laptop (with a video display from the robot's camera) will most likely be centered between the driver's two joysticks - though we are considering placing it between the manipulator and driver.
Unread 11-02-2015, 21:27
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
This year, a PS3 controller with driving and strafing on the right stick and turning on the left stick.
When we don't do holonomic drive, we like to modify an RC car pistol grip controller.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 11-02-2015, 21:54
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
We use wired Xbox 360 controllers. Our co-driver controls our elevator, which has presets. We thought it would be logical to use an Xbox 360 wired Guitar Hero controller, because the neck has five buttons in line, allowing for five pre-set elevator positions. The strumming switch will be used for fine adjustments in height. This is an idea so far, and our controller is orderd and being shipped. The driver holds the guitar controller as they would if they were playing Guitar Hero. Since we already know how to program Xbox 360 controllers, we can program a guitar controller since it is basically the same thing, just with a different shape.
We're gonna rock our regionals, and hopefully champs.
Unread 11-02-2015, 22:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It does depend on the game. I believe our driver used two of the KOP joysticks for Rebound Rumble, and an Xbox controller for the three years since. Our "gunner" usually uses the driver station keyboard, but I think he had some sort of controller to control the climb for Ultimate Ascent. There was an attempt to build a custom controller for Rebound Rumble, but we never got it reliable, probably more due to rookie issues than anything else. Each year, we look at the controllers we can have or get COTS to see if anything will work. If not, we're not scared to try again on a custom controller. If we did do one, it would probably be built on an arduino pro micro or leonardo as we've done some arduino programming for our non-competition projects.
Actually, that's pretty much our idea on most of the robot - look for a COTS item that we can afford and that can do (or be easily modified so that it can do) the job. Making the pieces work together is enough of a challenge that we don't design a totally new thing unless we see a big advantage to spending that much time and energy on it. Not having a good affordable COTS option constitutes a big advantage.
Unread 11-02-2015, 22:13
The Rock Band guitar does not distinguish between "strum up" and "strum down". If that's true of the Guitar Hero guitar as well, it won't be easy to use for up/down control.
Unread 11-02-2015, 22:19
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
For a few years, we've used a steering wheel and joystick for driving the robot, and if programmed right, it works GREAT. But that's only for high-speed/maneuverability/defense games like 2014 and 2013. It really depends on what kind of drivetrain you have and what the game is that year. While it's nice to have consistency from year to year and do one thing you know you can do well, sometimes you have to shake things up.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 11-02-2015, 22:35
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Actually, the logical solution would be to use a numeric keypad. But "Elevator Hero" is totally wicked.
Unread 11-02-2015, 22:59
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
We change from year to year depending on student preference.
The last two years we have been using the Logitech dual action game controller for the driver.
Last year the students took apart an Xbox 360 controller and made a custom control box that sits next to the console with lots of buttons and LED swag for the secondary drive to control various subsystems.
I will post some pictures when I get back to the school.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 11-02-2015, 23:26
bEdhEd's Avatar
I didn't play the game that much, but why do I remember scrolling up and down through song lists with the strumming switch? I know that it makes no difference when playing a song, but I swear that this switch is used for scrolling up and down menus.
Unread 11-02-2015, 23:28
bEdhEd's Avatar
We thought it was logical since they're in a row and serves as a more graphical representation of the elevator as a set of controls. The different colors are a bit more fun than numbers too.
Unread 12-02-2015, 09:20
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I get it, I like it, I may steal, uh, borrow it! I just consider this a "creative" rather than a "logical" solution. Unfortunately, the GH controllers here at the house are both wireless .
Unread 12-02-2015, 10:57
Team Role: CAD
Right now, our weapons officer/co-driver wants to use a turntable to control the elevators manually, but the programmers are saying the PID control scheme will work just fine with four levels for the elevator to snap to. I, personally, think a turntable would be super cool.
Unread 12-02-2015, 11:12
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Andy Baker once won an FRC regional... driving with only the Guitar Hero guitar.
(Sorry, I couldn't help myself.)
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
