Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 12-02-2015, 11:44
Nate Laverdure's Avatar
FRC #2363
Design and engineering mgmt rules
The various engineering industries seem to each have their own set of rules of thumb, collected from great minds and scraped from millenia of collective experience. Sometimes tongue-in-cheek, these are all about overcoming unique technical and nontechnical challenges. Occasionally they veer into the specific, but viewed as a whole, they can be seen as a set of philosophies for developing systems that consistently produce working designs.
Conveniently, building a high-functioning FRC team is also about developing systems that consistently produce working designs. As such, many of these rules are applicable to FRC.
Kelly Johnson, famed Lockheed systems and aeronautical engineer, developed his 14 Rules of management which he used to run Skunk Works for decades:
  • A very simple drawing and drawing release system with great flexibility for making changes must be provided.
  • There must be a minimum number of reports required, but important work must be recorded thoroughly.
  • Push more basic inspection responsibility back to [the people making the parts]. Don't duplicate so much inspection.
In particle accelerator design, there's the Gospel According to Bill Brobeck. I'll repeat the entire thing here because it's a rare find out in the wild:
  1. Thy bolt holes shall straddle thy center lines.
  2. Thou shalt look askance at gunks, glues, and potting compounds.
  3. When confronted with two solutions, both of which appear impossible, thou shalt choose the least expensive.
  4. Thou shalt not be misled when thy boss says, "I don't know much about this, but...".
  5. Thou shalt not use 1/4 inch bolts when one inch bolts will do.
  6. If thou canst step upon it, thou shalt design it strong enough so that all men may step upon it.
  7. Thou shalt bear in mind that welding is merely the casting of steel in the worst possible circumstances.
  8. Thou shalt design assemblies such that parts thereof may be placed in a funnel and come out assembled on the other side.
  9. Thou shalt stay with it until it works.
  10. Thou shalt not form ride pools.
In spacecraft design, there's Akin's Laws, now infamous because they were so widely circulated in the early days of the internet:
  • Engineering is done with numbers. Analysis without numbers is only an opinion.
  • Design is an iterative process. The necessary number of iterations is one more than the number you have currently done. This is true at any point in time.
  • In nature, the optimum is almost always in the middle somewhere. Distrust assertions that the optimum is at an extreme point.
  • Design is based on requirements. There's no justification for designing something one bit "better" than the requirements dictate.
What other lists of rules are out there?
Unread 12-02-2015, 12:36
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Design and engineering mgmt rules
Three Rules of Engineering:
1) Always us the right tool for the job
2) The right tool is always a hammer
3) Anything can be a hammer
Unread 12-02-2015, 12:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
To a man with only a hammer, all problems look like nails.
BTW, what sort of wrench do you recommend to hammer in a masonry screw?
Unread 12-02-2015, 13:01
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Adapting some old ASW (antisubmarine warfare) axioms into robotics terms:
  • Building robots is hard. If you're stupid, it's impossible.
  • The other alliance is never as clueless as you hope they'll be.
  • All tolerances are twice as large.
  • Speed is life. (no changes to that one)
Unread 12-02-2015, 13:31
If all you are is a nail, every hammer looks like a problem.
Unread 12-02-2015, 13:54
AKA: Matt Hagan
I would suggest a 30 oz Freshman adjuster.
Unread 12-02-2015, 16:03
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
My team's favorite for jobs like that is the left-handed French metric adjustable open-ended magnetic reverse-ratcheting box wrench.
It's not done until it's overdone!
Unread 12-02-2015, 16:12
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I'm guessing that your handle derives from the shape of your robots.
Unread 12-02-2015, 18:36
A Langstrom 7-inch Gangly wrench
Unread 12-02-2015, 18:56
Best Available Data
FRC #1778 (Chill Out!)
Quest oculus non vide, cor non delet
What the eye does not see, the heart does not regret
"A lot happens that we are not telling you about."
-- Opening comments from the Apollo guidance computer source code (per Digital Apollo)
"This machine was so modern, so frightfully new, no one knew quite exactly just what it would do!" -- Dr. Seuss, The Butter Battle Book
Unread 12-02-2015, 23:59
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
HAW HAW HAW! And best fishes to you, as well!
Unread 12-02-2015, 12:45
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Mystery Solved!
For years, I've wondered why spacecraft occasionally disintegrate, but I've never head of a particle accelerator disintegration. Now I know why.
  • 5. Thou shalt not use 1/4 inch bolts when one inch bolts will do.
Unread 12-02-2015, 13:30
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: Mystery Solved!
Oh, it's possible:
https://edms.cern.ch/file/973073/1/R...at_LHC__2_.pdf
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 12-02-2015, 16:34
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Re: Mystery Solved!
Originally Posted by AustinH View Post
Did you notice the Final Recommendations...Increase all bolts from 1" bolts to 4" Bolts!
Unread 12-02-2015, 16:55
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Mystery Solved!
Never use a 1" bolt when a 4" bolt will do.
