Go to Post there is no such thing as too many offseason competitions. - Berserker [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
  #91   Spotlight this post!
Unread 11-02-2015, 18:19
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Al's Annual Inspection Thread 2015
It's not an unusual issue, even for experienced teams.
I was inspecting the wiring from our CIM motors back to the speed controllers, and asked whether they had looked at the wiring table. Turns out they matched the wire off of the CIMs, rather than using the table. Fixing it is now on our punch list.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
  #92   Spotlight this post!
Unread 12-02-2015, 13:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Another pneumatic system question: does the steel NPT fitting, standard on the Viair compressors, need to be installed?
It is the compressor's fitting that typically comes with a plastic plug in it, seen here:
  #93   Spotlight this post!
Unread 12-02-2015, 13:32
ATannahill ATannahill is offline
AKA: Alex Tannahill
The pressure relief valve must be attached to the compressor with legal hard (non tube) fittings, so if you chose to install the NPT to plastic plug fitting, it must be past the pressure relief valve.
Originally Posted by R76
The relief valve must be attached directly to the compressor or attached by legal hard fittings (e.g. brass, nylon, etc.) connectedto the compressor output port. If using an off-board compressor, an additional relief valve must be included on the ROBOT.
  #94   Spotlight this post!
Unread 12-02-2015, 13:33
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
It comes installed, so you would have to take it off. That sounds like modification to me.
Why don't you want it? It doesn't add much weight, and it gives you an easy adaptation to a tee fitting for the relief valve.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
  #95   Spotlight this post!
Unread 12-02-2015, 13:37
AKA: Alex Tannahill
I believe that modification is legal under R65-C since it is pre-existing threads.
  #96   Spotlight this post!
Unread 12-02-2015, 13:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
True... but irrelevant to my question.
Removing a pre-installed fitting would be like changing the terminal screws on a Victor. Yeah, it's not precisely the original hardware, but from a safety and function perspective it hasn't changed.
The steel coupler pushes a few fittings and a gauge to a spot that's less accessible (and makes the gauge less readable) so it is handy to not have it in place.
The port in the compressor is 1/8NPT, so attaching normal hard-fittings and tees is the same as attaching to the steel part, it just fits into our robot a bit more easily.
  #97   Spotlight this post!
I might be missing something really simple, but I never understood this rule. If the device in question has 14 AWG wire standard, why do I have to feed it with 12 AWG? Are we trying to say that the manufacturer is not using the proper wire? A CIM on a 40 AMP breaker will draw a good amount of current if you tell it to, but why doesn't the CIM wiring dictate what wire is used between the breaker and the speed control?
How does it make sense that I would have to crimp 12 AWG wire to 14 AWG wire after the speed controller to be legal? How does that help?
Andrew Basse
  #98   Spotlight this post!
Unread 12-02-2015, 13:44
I guess I would counter by saying that you can modify electronics practically all you want. Pneumatics have painful rules in place to prevent accidents that may happen when people don't understand a system.
R65 C might give you a little leeway with that idea though since you are using the existing threads.
Andrew Basse
  #99   Spotlight this post!
Unread 12-02-2015, 13:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Are you sure about that? See R55.
R65-C is why I assume our actions are legal, but I just want to double-check with the in-field experts.
  #100   Spotlight this post!
Unread 12-02-2015, 14:01
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Because you put it on a circuit capable of feeding 40 amps. The RI looks at the PDB and breakers. If you put a 40 amp breaker in the PDB, then that connection has to have 12 AWG wire. The RI doesn't have to follow the circuit to see what it is connected to.
  #101   Spotlight this post!
Unread 12-02-2015, 14:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
CIM wire leads also have insulation that can take more heat than the insulation that's on most wires.
  #102   Spotlight this post!
Unread 12-02-2015, 14:06
I think "installed" is the key word. R65 says the original condition. "optional" parts are not part of the original condition.
Now, if it came with it installed, then the question is whether R65-C applies since you would be "disassembling" to remove the NPT fitting, and not "assembling".
  #103   Spotlight this post!
Unread 12-02-2015, 14:10
Another thought:
FIRST doesn't want you replacing wires that were not intended to be replaced. Thus the concession granting exception to using wire as supplied by the manufacturer.
  #104   Spotlight this post!
Unread 12-02-2015, 14:11
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The only part that is required to be connected by hard fittings is the relief valve. Hook up a T with a relief valve on it, then use some tubing to located the gagged and switch and such someplace more accessible.
2016: Lake Superior WFFA
  #105   Spotlight this post!
Unread 12-02-2015, 14:12
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Just to verify:
PDB <-> 40A Breaker <-> 12AWG wire <-> Victor <-> 14AWG wire directly attached to CIM
Legal?
Nate
