Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Unread 12-02-2015, 14:45
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Fork Lift controls
Who amongst you have forklift mechanisms on your bot ?
How do you have your joystick controls programmed/wired ?
A mentor drove a forklift before and the controls standard for a forklift is
for the joystick to be pulled back to raise the fork ...
Page 37 in this standard:
https://law.resource.org/pub/us/cfr/...b56.1.1969.pdf
I know that the controls should be what the operator wants for some teams. For us, we programmed it that way and retrained our operators. It made sense for some of them, and did not for some of them.
Unread 12-02-2015, 14:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Fork Lift controls
The standard may be setup like a fighter pilot since the load is in front of him and the joystick is big enough to require the entire hand while driving a real forklift. Pull back on the stick, start looking up - just like a fighter pilot.
For thumb-sticks, it doesn't matter IMO. Pull back on the stick and you're still looking straight out.
We have a bit of automation in ours, but ours isn't a typical forklift either.
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
We're using a sliding pot to set the position of the lift with a separate button that will bring it to the bottom when pressed, then return it to the set position when released. With PID on the lift motor this should allow us to take the height of the lift to any position we like and allow for a quick stacking motion.
Unread 12-02-2015, 14:57
KPSch KPSch is offline
AKA: Ken Schenke
FRC #1987 (Broncobots)
KPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to allKPSch is a name known to all
The best controls are ones that make sense to your drive team. They're the ones that have to be driving in the heat of competition. Every year our programmers develop driving code for a traditional joystick and an Xbox controller. For driver tryouts we allow each student to pick which they'd like to drive with. When the drive team is selected, the drive team (not the mentors, coaches, or other students) picks button and stick axis assignments.
Your drive team should be telling the programmers how the robot is controlled, not the other way around.
Unread 12-02-2015, 15:05
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have a forklift, though it has about 20 tines instead of two and they are vertical rather than horizontal.
I believe that our prototype control uses a horizontal joystick axis. Our final one will probably have a "manual" joystick control, but most of the lift and lower commands will be issued through buttons. We're coding a number of pre-defined positions into the lift.
The bottom line is, find something that the drivers can work with as early as possible, and practice, practice, practice! Don't tweak it unless it is requested by the drive team.
Unread 12-02-2015, 15:17
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Remember, if you are automating like this, to always always always give your drivers a non-automated manual override. Because when that sensor feedback breaks and your automated PID isn't functioning, you still want them to be able to control it.
Unread 12-02-2015, 16:45
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
EDIT: OOPS, wrong thread.
Jim Browne, EIT
Team 1058 - PVC Pirates
