Go to Post When I judge a robot, the single most important factor to me is whether or not the robot is rigid. - Gressa [more]
Unread 12-02-2015, 15:49
Jared Russell's Avatar
Taking a year (mostly) off
Re: Drive Train Curves Only While Backing Up
Originally Posted by Ozuru View Post
I just changed the testing code to this now and the issue persists. Shouldn't this have fixed it?
package org.usfirst.frc.team2559.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
	Talon talonleft0 = new Talon(3);
	Talon talonleft1 = new Talon(4);
	Talon talonright0 = new Talon(5);
	Talon talonright1 = new Talon(6);
	RobotDrive rDrive;
    public void robotInit() {
    	rDrive = new RobotDrive(talonleft0, talonleft1, talonright0, talonright1);
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
    	rDrive.tankDrive(-0.4, -0.4);
    public void teleopInit() {
     * This function is called periodically during operator control
    public void teleopPeriodic() {
     * This function is called periodically during test mode
    public void testPeriodic() {
RobotDrive by default inverts the command to your right side drive motors (the authors assumed you'd wire red to + on both sides), so calling tankDrive(-.4, -.4) actually sends -.4 and +.4 to your Talons.
tankDrive(-.4, .4) or visa versa should result in identical pulsewidths.
