Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Unread 11-02-2015, 18:00
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Exclamation PCM slow red flash
The PCM is slowly flashing red. The CAN is wired properly, there are no compressor or solenoid faults (still flashes red when there's no solenoid or compressor) and the power is from a fresh battery. How can it be fixed?
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 11-02-2015, 18:05
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: PCM slow red flash
You mean the STATUS LED is slowly blinking red? And the COMP LED is off I assume?
Robot is disabled or enabled when the STATUS LED is blinking red?
Does the PCM show up in the roboRIO Web-based config? If not check the CAN wiring. How did you confirm the CAN wiring?
Do you mean it does show up in the roboRIO web-based config and your confirmed it's not faulting by pressing Self-Test?
Unread 11-02-2015, 18:14
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Yes, it's the status light.
It flashes red for both.
No, it doesn't show up there. I have the CAN wired from the roboRIO to the PCM to the PDP. And the PDP works, so, as far as I can tell, the CAN is working.
Unread 11-02-2015, 18:29
ozrien's Avatar
Omar Zrien
AKA: Omar
Does the PDP show up in the roboRIO Web-based configuration page? What is the blink pattern on the PDP (both LEDs should blink the same)?
Unread 11-02-2015, 18:34
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Yes the PDP shows up on the web-based configuration page, and both LEDs blink green.
Unread 11-02-2015, 19:08
ozrien's Avatar
Omar Zrien
AKA: Omar
Maybe take a pic of the wiring and send it to support@crosstheroadelectronics
Did the PCM ever blink green or orange before?
Unread 12-02-2015, 16:35
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Yes.
We just got another PCM for our practice bot, and we tested that one, and it worked.
