Go to Post Rule 1. Never take Dave's hint's seriously. Rule 2. Watergame. - AndyB [more]
Unread 12-02-2015, 17:06
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Python: Robot Drive is not updating often enough in Auto mode?
Hi! We are trying to create some auto mode code but we keep getting a "WARNING: wpilib.motorsafety : Robot Drive.... Output not updating often enough". We are using a string of elif statements with the auto counter to avoid using for loops and while loops.
        if self.auto_loop_counter<=25:
            self.non_existant_motor.set(-.5)
            self.sol.set(True)
            self.auto_loop_counter+=1
        elif self.auto_loop_counter <= 100 and self.auto_loop_counter>25:
            self.robot_drive.drive(-0.5, 0) # Drive forwards at half speed
            self.auto_loop_counter += 1
            self.sol.set(False)
            self.non_existant_motor.set(0)
        else:
            self.robot_drive.drive(0, 0)
We have many more elifs then that but that is the basic framework of our code. Any help will be greatly appreciated!
Unread 12-02-2015, 17:14
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Python: Robot Drive is not updating often enough in Auto mode?
Robot drive not updated often enough is an error you'll receive when your code isn't executing in a short enough amount of time. Don't quote me on it, but I think you'll receive the error if your code doesn't send a control message to the robot every 100ms.
Why are you trying to avoid for and while loops?
Unread 12-02-2015, 17:32
The code that prints this error is in motorsafety.py and looks like this
 def check(self):
        """Check if this motor has exceeded its timeout.
        This method is called periodically to determine if this motor has
        exceeded its timeout value. If it has, the stop method is called,
        and the motor is shut down until its value is updated again.
        if not self.safetyEnabled or RobotState.isDisabled() or RobotState.isTest():
            return
        if self.safetyStopTime < Timer.getFPGATimestamp():
            logger.warn("%s... Output not updated often enough." %
                        self.getDescription())
            self.stopMotor()
It looks like SafePWM (the base class for Victor and Talon) inherits this class. So, basically, if you don't call .set() on your motor controller object periodically it will assume your code has run away from you and stop that particular motor. The default timeout is 0.1 seconds.
Your auto code is only calling robot_drive.drive in some parts of the if structure. Therefore, the set method on those speed controllers isn't being called, hence this message printing.
You can fix this by:
1) Disabling motor safety by calling setSafetyEnabled on the motor object
2) Calling set on each motor in each iteration. I suggest something like the following:
       non_e_motor_out = 0
       drive_out = (0,0)
            non_e_motor_out  = -.5 #
            self.sol.set(True)
            drive_out = (-0.5, 0)  # Drive forwards at half speed
            self.sol.set(False)
        self.robot_drive.drive(drive_out[0], drive_out[1])
        self.non_existant_motor.set(non_e_motor_out)
Unread 12-02-2015, 21:07
team-4480's Avatar
Debug? What's that?
FRC #4480
Thanks to both of you and I will try out that code as soon as I can!
Unread 12-02-2015, 22:12
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Hopefully you run your code through the simulator... right?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 12-02-2015, 23:09
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Definitely make sure you run your autonomous through the simulator, it'll show things like that and you can fix them there before putting it on the robot.
Additionally, don't forget that there's a really simple autonomous framework you can use in python. Check it out: http://robotpy-wpilib-utilities.read...ful_autonomous
Unread 13-02-2015, 00:12
virtuald's Avatar
RobotPy Guy
Also, I just uploaded a sample of the autonomous framework, if you want to play with it. Very simple to use, and a great way to manage simple state machines for autonomous mode.
https://github.com/robotpy/robotpy-w...master/samples
