Go to Post Be the change you want to see. - staplemonx [more]
Unread 12-02-2015, 17:19
5580SQUAD 5580SQUAD is offline
FRC #5580
5580SQUAD is an unknown quantity at this point
How to make the camera work? (Java)
We are trying to get the camera to show it's display on the dashboard but we've failed to get any kind of input showing.
And here's our code:
package org.usfirst.frc.team5580.robot;
import com.ni.vision.NIVision;
import com.ni.vision.NIVision.DrawMode;
import com.ni.vision.NIVision.Image;
import com.ni.vision.NIVision.ShapeMode;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Timer;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
        final int JOYSTICK_PORT = 0; //Computer port 0
        final int FRONT_LEFT_SC = 1; //PWM, PORT 0
        final int FRONT_RIGHT_SC = 2; // PWM, PORT 1
        final int BACK_LEFT_SC = 3; // PWM, PORT 2
        final int BACK_RIGHT_SC = 4; //PWM, PORT 3
        final int LIFT_SC = 5; //PWM, PORT 4
        int session;
    Image frame;
        Joystick driver;
        Talon frontLeft;
        Talon frontRight;
        Talon backLeft;
        Talon backRight;
        DoubleSolenoid sol1;
        Compressor comp;
        Talon lift;
        CameraServer camera;
    public void robotInit() {
        driver = new Joystick(JOYSTICK_PORT);
        frontLeft = new Talon(FRONT_LEFT_SC);
        frontRight= new Talon(FRONT_RIGHT_SC);
        backLeft = new Talon(BACK_LEFT_SC);
        backRight= new Talon(BACK_RIGHT_SC);
        sol1 = new DoubleSolenoid(0,1);
        comp = new Compressor(0);
        comp.setClosedLoopControl(true);
        lift = new Talon(LIFT_SC);
        frame = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
        // the camera name (ex "cam0") can be found through the roborio web interface
        session = NIVision.IMAQdxOpenCamera("cam0",
                NIVision.IMAQdxCameraControlMode.CameraControlModeController);
        NIVision.IMAQdxConfigureGrab(session);
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
        while (isEnabled()&&isAutonomous()){
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        while (isEnabled()&&isOperatorControl()){
                double leftSpeed = driver.getRawAxis(1)*-1;
                double rightSpeed = driver.getRawAxis(5);
                double turns=driver.getRawAxis(3)*-1;
                boolean liftSpeed = driver.getRawButton(2);
                boolean liftSpeed1 = driver.getRawButton(3);
                frontLeft.set(leftSpeed);
                backLeft.set(leftSpeed);
                frontRight.set(rightSpeed);
                backRight.set(rightSpeed);
                        boolean push = driver.getRawButton(1);
                        boolean pull = driver.getRawButton(4);
                        if(turns <0){
                                frontLeft.set(turns);
                        else if(turns>0){
                        if (liftSpeed == true){
                                lift.set(1);
                         else if(liftSpeed1 == true) {
                                 lift.set(-1);
                                else {
                                lift.set(0);
                if (push == true){
                  sol1.set(DoubleSolenoid.Value.kReverse);
                if (pull == true){
                        sol1.set(DoubleSolenoid.Value.kForward);
    public void operatorControl() {
        NIVision.IMAQdxStartAcquisition(session);
         * grab an image, draw the circle, and provide it for the camera server
         * which will in turn send it to the dashboard.
        NIVision.Rect rect = new NIVision.Rect(10, 10, 100, 100);
        while (isOperatorControl() && isEnabled()) {
            NIVision.IMAQdxGrab(session, frame, 1);
            NIVision.imaqDrawShapeOnImage(frame, frame, rect,
                    DrawMode.DRAW_VALUE, ShapeMode.SHAPE_OVAL, 0.0f);
            CameraServer.getInstance().setImage(frame);
            /** robot code here! **/
            Timer.delay(0.005);         // wait for a motor update time
        NIVision.IMAQdxStopAcquisition(session);
     * This function is called periodically during test mode
    public void testPeriodic() {
If you have any idea on what we should do please post a reply
Unread 18-02-2015, 13:02
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Re: How to make the camera work? (Java)
We got it to work by getting the cameraServer instance, calling the cameraServer with "cam0" argument and calling the start capture method.
Unread 18-02-2015, 13:07
FRC #0537
CameraServer cams = CameraServer.getInstance();
// set any cam parameters, then start capture
cams.startAutomaticCapture("cam0");
Unread 18-02-2015, 16:18
JML's Avatar
JML JML is offline
Jlyon
AKA: Jlyon
FRC #3044 (0xBe4)
JML is an unknown quantity at this point
Our team had trouble viewing the camera on the default dashboard, viewing it with smart dashboard or another program may be easier. To use smart dashboard, you send the image with the camera server class (we don't use automatic capture so we can set the frame rate)
 int count = 0;
		currentTime = Timer.getMatchTime();
		if (count > 3) {
			lastUpdateTime = currentTime;
			count = 0;
		count += 1;
Edit: You also need to hit the play button for it to play on the Default Dashboard
Unread 18-02-2015, 16:45
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Our team had to set the quality to 25% for the feed to show
Unread 19-02-2015, 00:18
The play button is not associated with the camera image.
