Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 12-02-2015, 10:01
JohnFogarty's Avatar
Trapped under a pile of Mechanums
AKA: @doctorfogarty
pic: 4901 won't run out of air this season. That's for sure.
Unread 12-02-2015, 10:03
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Re: pic: 4901 won't run out of air this season. That's for sure.
What's the weight?
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 12-02-2015, 10:06
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by JohnFogarty View Post
How long does it take to charge that thing?
... and for that matter, how long does it take to dump after the match?
___________________
- Tennyson, Ulysses
Unread 12-02-2015, 10:08
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Harbor Freight has the tank listed at 15 pounds. About the same weight and capacity of 30 clippard tanks.
I'm smiling looking at this photo. We had similar air use issues with our pneumatic elevator in Week 4 because of the way we (mis)read the compressor specs. Our choice was either mount 30 tanks, or retrofit a motorized winch. We went with the winch, but the switch ate up most of Week 5 (and a good chunk of our budget). I hope the "more tanks" choice works well for you!
Unread 12-02-2015, 10:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
it takes our little Viair compressor just over half a minute to fill our one long skinny (2012 KOP) metal storage tank. I'm guessing it will take that compressor at least 5 minutes to fill the big tank. Hopefully you can get it done before each match....
Unread 12-02-2015, 10:55
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We are using that same compressor, and a metal Viair tank. However, we are thinking that half a gallon of air should be enough.
Five gallons is a lot of air. Based on measurements my team reported earlier, I would estimate this compressor would require about four minutes to recharge a five gallon tank from ~100 PSI back to ~120 PSI. So with a tank that large, it is unlikely you would see a benefit from have the compressor on board.
Richard Wallace
since 2003
Unread 12-02-2015, 11:00
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
...without burning up that compressor that I'm guessing wasn't designed for continuous duty.
Unread 12-02-2015, 11:04
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Last year, I saw a team from Mexico do something similar. It took them about 5 minutes to recharge. If they made it to the finals, I have no idea what they would do to reset for the back to back matches.
Unread 12-02-2015, 11:12
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Actually, the VAIR 250c is rated for a 100% duty cycle.
--Jacob
Illinois FTC FTA
Unread 12-02-2015, 11:14
tickspe15's Avatar
tickspe15 tickspe15 is online now
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
The compressor they are using, the viair 250C, is rated for continuous duty.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 12-02-2015, 11:28
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Why would they dump their stored air after the match?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 12-02-2015, 12:38
MrForbes's Avatar
AKA: Jim
Without seeing the rest of the robot design, we can only guess.
Unread 12-02-2015, 14:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I believe that this was explicitly required in previous years - that all stored air must be dumped at the end of the match. I couldn't find anything stating or implying so in the 2015 game manual.
Unread 12-02-2015, 14:37
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
If you find yourself close on weight, go for the 7gal aluminum one at HF. Saves a little bit and then you'll really have to try to run out of air.
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
Unread 12-02-2015, 17:36
AKA: @doctorfogarty
We did a lot of math on the volume of air our Cylinders use per stroke and we found that an air tank with volume like this is almost a necessity.
The tank is 15 LBS. (I am aware of the light weight version at harbor freight and we'll keep that in mind if weight is problem, which at the moment our robot is about 30 pounds under weight without the tank on.
Our plan was to use the compressor off-board. If we needed extra weight...on it would go. The compressor is also roughly 15 pounds.
100% Duty cycle at 100 PSI. Charge time is 5 minutes from empty to full. We don't need to empty the system after every match. We would only do so in the times where we needed to. I also checked the rules for that.
John Fogarty
