Go to Post This pic became proof that engineers should never give up thier day jobs! :p - Jay H 237 [more]
Unread 12-02-2015, 18:47
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
Re: Controlling Motor Turns Autonomous
We're using these encoders: http://www.andymark.com/product-p/am-0180.htm
I'd like to use them on our drive train during autonomous (which has no gearbox (it's just a cim on each side)), and on our lead screw lift mechanism during teleop to hit various levels.
I've looked at some previous posts about encoders, and also at the Team 358 example, but I'm still a little lost at how to program and/or mount them.
Unread 12-02-2015, 19:46
Originally Posted by btcshields6 View Post
our drive train ... has no gearbox (it's just a cim on each side)
You're probably not going to be too happy with that arrangement.
Unread 12-02-2015, 20:20
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
...drive train during autonomous (which has no gearbox (it's just a cim on each side)), and on our lead screw lift mechanism during teleop to hit various levels...
Have you confirmed that you can drive without tripping the 40 amp breakers?
Unread 12-02-2015, 21:38
...I'm still a little lost at how to program and/or mount them.
The Encoder example in LabVIEW shows how to wire and how to program them.
The am-0180 is designed to be attached to one of several specific gearboxes, or to a custom gearbox with the same short 1/4" shaft and mounting hole pattern. Mounting it is going to be rather problematic without such a gearbox.
