Go to Post I love it when awards go to the right people. - David Kelso [more]
Unread 12-02-2015, 20:56
MariOlsen MariOlsen is online now
FRC #5416
MariOlsen will become famous soon enough
Solenoid Actuator Legality
Our team is using these solenoid actuators:
http://www.amazon.com/400mA-Frame-So...productDetails
It's a bit late, but we wanted to make absolutely sure we satisfy R18, specifically that they have a "rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)". Since the specs don't list a power rating, we used P=IV to calculate that (.4A)*(12V)=4.8W. Was this the correct approach? Thanks!
Unread 12-02-2015, 23:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Solenoid Actuator Legality
Looks correct to me (MS Physics) - the power can't be any greater than VI. Be sure to bring a copy of (and link to) the "See more product details" page to competition so you can make your case with the inspectors.
Unread 13-02-2015, 00:06
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
Just to let you know. Your PCM will only be able to handle one of those solenoids. The PCM per cross the road's manual can only handle a load of 500mA across the solenoid ports.
If you were going to use a spike relay you can ignore my previous statement.
John Fogarty
Unread 13-02-2015, 00:23
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Absolutely. Solenoids controlled by the PCB (which I hadn't though of because it wasn't stated as a pneumatics issue) have much stricter standards in terms of current/power draw.
Unread 13-02-2015, 10:58
FRC #5416
Thanks! We are using a single Spike to run both.
