Go to Post my theory on the matter was always something along the lines of "Oh, we're all girls? What an odd thing for you to notice." - karinka13 [more]
Unread 12-02-2015, 21:30
RobLikesRobots's Avatar
RobLikesRobots RobLikesRobots is offline
Team Role: Game Rules Monitor
AKA: Robert
FRC #0269 (CooneyTech Robotics)
RobLikesRobots is an unknown quantity at this point
Legal Belt Dressing?
Hi. My team has designed an intake that uses belts to suck totes into the robot. To get better grip, we sprayed the belts with Cyclo Heavy Duty Belt Dressing. Does this method of increasing belt traction break rule R16 "Lubricants may only be used to reduce friction within the ROBOT. Lubricants may not contaminate the ARENA or other ROBOTS." Another teammate and myself believe that the dressing violates the rule, but we want to know what the Chief Delphi community thinks, just to be sure.
Unread 12-02-2015, 21:35
Re: Legal Belt Dressing?
Lubricants, by definition, decrease friction. What you have there is not a lubricant. It's the opposite.
That being said, is it rubbing off on the totes? If it is, then there is the potential for a "damage" call going against you.
Unread 12-02-2015, 21:40
AKA: Robert
Yes, the dressing does rub off when touched, so it is likely that it will come off on totes
Unread 12-02-2015, 21:43
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Then it could also fall under G25:
ROBOTS may not intentionally detach or leave parts on the FIELD.
VIOLATION: RED CARD
Unread 12-02-2015, 21:44
Then I would consider using some other form of friction increasing agent (say, grippier tread). It's quite possible for G16 (specifically part D) to be invoked, in the form of "take that off of your robot before you come back out here".
And yes, I think R16 can also be applied. This would be the reason given for the application of G16.
Unread 12-02-2015, 22:14
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
I think you're pushing it with the belt dressing, personally I would stay away from anything spray on / "liquidy" especially if it could rub off on the totes
Unread 12-02-2015, 22:40
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Id say yes that's a rule breaker. You are transferring the belt dressing to the game piece.
Unread 14-02-2015, 11:19
AKA: Robert
We've decided to find a better method. Thanks for your help everybody!
Unread 14-02-2015, 21:22
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Good luck
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
