Go to Post How many programmers does it take to change a light bulb? None. They'll just say it's a hardware problem. - crafty [more]
Unread 12-02-2015, 21:42
rwodonnell rwodonnell is offline
AKA: Rick O'Donnell
FRC #2876 (Devilbotz)
rwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to beholdrwodonnell is a splendid one to behold
5K ohm 10 turn Potentiometer trouble
We have the AndyMark Bourns 5K 10 turn pot: 3590S-2-502L (datasheet: http://files.andymark.com/am-2619.pdf). When plugged into the roboRIO, we can't see any noticeable changes in the SmartDashboard when we turn the potentiometer, even manually. We've replaced it with a 270 degree 100K ohm potentiometer (and changed the settings appropriately with RobotBuilder) and see the results we would expect in SmartDashboard. We need more than a single turn potentiometer to execute our plan.
Is it possible to use a 5K pot, or do we need to get a higher resistance model?
We've confirmed the wiring and AI port, and don't believe it has anything to do with those types of errors.
Unread 12-02-2015, 21:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 5K ohm 10 turn Potentiometer trouble
Just to verify - do you have the red and black wires connected to the ends of the resistor, and the white to the "sweep"? (I'm assuming the usual 3-wire arrangement, black=0V, red=5V, white=signal.)
You can check this by unplugging the pot from the 'RIO and measuring the resistance between red and black with a meter - it should stay constant at about 5K no matter what position the knob is in.
Then, measure the resistance between white and either of the others - it should sweep from 0 ohms at one end to 5K at the other.
5K should work just fine. We're using a 10K 10-turn pot from Jameco, and 5V should work oh-so-slightly better for measurement purposes, at the trivial cost of drawing a full mA of current as opposed to a half mA.
Unread 12-02-2015, 21:51
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
This looks just like the Jameco pot we have. It is a bit unusual for a potentiometer in that the "sweep" on ours is at the back end - the farthest from the knob; usually the sweep is in the middle.
Confirmed from the data sheet - look at the diagram at the lower left of the second page. The back connector is the sweep.
Unread 12-02-2015, 23:01
AKA: Rick O'Donnell
Thank you GeeTwo! We are fixed! Our electrical guys feel a little sheepish, and I am hiding behind my "programming mentor" shield...
Thanks again!
Unread 12-02-2015, 23:24
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Thanks again!
My pleasure - and we probably would have gone through the same drill if I hadn't had a strange feeling as I looked at the arrangement of lugs and decided to put a meter on the pot rather than assume that the sweep was in the middle.
