Go to Post NERDs...gotta collect them all! - Conor Ryan [more]
Unread 12-02-2015, 23:09
itwasntme455 itwasntme455 is offline
AKA: Brandon
FRC #4791 (Pandroids)
itwasntme455 is an unknown quantity at this point
max drive speed limiter
I would like to make it if the joystick is pushed all the way up in arcade drive the motors won't be at 100%. How can I do this? We are using the default programming that came with LabVIEW.
Unread 12-02-2015, 23:14
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: max drive speed limiter
Do you want to cap the input (so any input beyond the limit is read as the limit) or do you want to scale the input (so 100 is read as the limit, 50 is read as half of the limit, ...)?
Unread 12-02-2015, 23:17
You can run the joystick axis value through an In Range and Coerce function to clip it at whatever maximum value you want, but that will just mean some of the physical joystick travel will be of no use.
You can multiply the joystick axis value by a percentage. That will maintain the full range of joystick travel, while making the maximum value whatever percent you chose.
Unread 12-02-2015, 23:25
AKA: Brandon
So if we want the max to be 50%, how would I do that? What is an "In Range and Coerce" function?
Unread 13-02-2015, 08:11
You have two wires going from your joystick axes to your Arcade Drive. Insert a Multiply function on each wire and multiply both values by 0.5, and that's all it takes.
When you have a VI's block diagram open, you can press control-space and bring up a search window. Type the first part of the name of the function you are interested in. You can place the function by clicking on it and then on the spot in the diagram you want it to appear. If you have LabVIEW's "hover help" turned on (press control-H) you can get information about pretty much anything by holding the cursor over it. For functions, there is almost always a link to the equivalent of a manual page, describing what it does and how to use it.
Unread 13-02-2015, 13:21
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
The easy way to do this is to multiply your joystick output by some number. If you want 50% then just multiply your output by 0.5.
