Go to Post It isnt about winning and losing (although getting the trophies and medals are nice) - Winged Wonder [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 11-02-2015, 15:19
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: C++ Command Based Robot Template
Yes, the new project I created has CommandBase.cpp and CommandBase.h.
It's hard for me at this point to know what exactly your question is.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 11-02-2015, 15:23
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
There is no question. Look at the original post and you'll see I did not ask for help with anything. I was simply stating a problem I ran into and then saying how I fixed it.
Unread 11-02-2015, 16:54
This looked a lot like a question:
Has anyone else noticed that the included template does not work correctly?
Unread 11-02-2015, 18:23
The main problem with RobotBuilder so far for us is the lack of CANTalon support.
You might find the discussion in http://www.chiefdelphi.com/forums/sh....php?p=1437494 helpful.
Also, we have ~7 Windows computers and 1 Mac, and currently RobotBuilder only opens on the Mac, except for the fact that it does not export.
RobotBuilder is a Java app and runs for others using Windows just fine. You seem to be having a lot of unique problems. I don't know why that is, but I suspect a systemic failure in translating from the ScreenSteps instructions to your system.
Unread 12-02-2015, 18:47
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Sorry to revive this thread, but is it just me, or is the CANTalon not LiveWindow Sendable? If so, what do you guys do for test mode? Because the livewindow is awesome for testing stuff but it would totally suck if it doesn't support CANTalons :/
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 12-02-2015, 19:01
AKA: Isaac
I have not used test mode, so I wouldn't know how to do that, but things like RobotDrive also do not support the CANTalons so I wouldn't be surprised if LiveWindow didn't, either.
What does the code look like that you're trying to use?
Unread 12-02-2015, 21:09
...things like RobotDrive also do not support the CANTalons...
That is not the case. RobotDrive will support any speed controllers you can instantiate.
Unread 12-02-2015, 21:36
AKA: Isaac
Have you verified this by creating a RobotDrive object within C++ and having it drive a robot? If so, this would be very helpful for us, as so far, in our experience, RobotDrive will not work with a CANTalon setup.
Unread 12-02-2015, 22:38
I don't use C++, so I have not verified it personally. But I count at least a half dozen teams who have posted on Chief Delphi about doing it. Here's a post containing code that explicitly says it works.
Unread 12-02-2015, 22:51
AKA: Isaac
That thread has the RobotDrive initializing with PWM. Not CAN. It says so in the comments of the code. This does not show that RobotDrive works with CANTalon.
Unread 12-02-2015, 23:09
Omar took the Driving a robot using Mecanum drive example, changed it from PWM to CANTalon, and added gyro features. He just didn't fix the comments, that's all. If you look at the actual code, you won't see any PWM use.
Unread 12-02-2015, 23:24
AKA: Isaac
Even if the code compiles, it does not mean it'll absolutely work. I have tried to use RobotDrive with the CAN and it does not work for me. If other people have it working, good for them, but in my experience from using the RobotDrive with CANTalons in C++ it will not drive.
Unread 12-02-2015, 23:27
AKA: Isaac
Please, anyone, feel free to prove me wrong by writing out a simple program that uses RobotDrive and CANTalons in C++ to drive. If you do, please upload your code so I can save it for future reference, and if you can, a video showing the robot driving would be nice too!
Unread 13-02-2015, 00:57
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Wow, you must not think much of my examples. Well...I'm not sure what else I can do for you besides giving you functional code that I tested on my robot, which is available per Alan's suggestion. I'm not really sure what you are asking for from the community at this point. Do you really think I would not test it on an actual robot before posting it?
At any rate if you're really that unhappy with robotbuilder, then I would recommend using a clean IterativeRobot project. If you don't like RobotDrive, implement your own drive train class.
I'm not sure what problem you are seeing with RobotDrive. The only problem I've heard of and confirmed is that RobotDrive tends to trip MotorSafety occasionally, which is easy to workaround by calling RobotDrive:SetSafetyEnabled(false).
Sparkyshires brought up a good question. I'm not sure if the LiveWindow Sendable interface is implemented (I don't have the code in front of me). If it's not I'm sure you could put together an easy wrapper to hook it up, or someone from the community could recommend a way to go about it.
Unread 13-02-2015, 01:20
AKA: Isaac
Sorry, I did not mean to insult your examples in anyway. It's just that with RobotDrive and the CANTalons haven't been working at all for me, and its a little frustrating. We use the command based robot, as shown by the template I made, and from what I've seen the command based is an iterative robot with all the pieces broken up, which is what the team uses to also train people to use classes and such.
