Go to Post Progress should never made at the expense of the past. - Koko Ed [more]
Unread 12-02-2015, 22:40
Lemon's Avatar
Lemon Lemon is offline
Builder of Robots
AKA: Andrey (Gooby)
FRC #2383 (Ninjineers)
Team Role: Electrical
Lemon is an unknown quantity at this point
Re: pic: 4901 won't run out of air this season. That's for sure.
Well I guess we aren't the only team going with a lot of air this year, although we do have you beat by one gallon
Unread 12-02-2015, 22:53
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Originally Posted by JohnFogarty View Post
We did a lot of math on the volume of air our Cylinders use per stroke and we found that an air tank with volume like this is almost a necessity.
The tank is 15 LBS. (I am aware of the light weight version at harbor freight and we'll keep that in mind if weight is problem, which at the moment our robot is about 30 pounds under weight without the tank on.
Our plan was to use the compressor off-board. If we needed extra weight...on it would go. The compressor is also roughly 15 pounds.
100% Duty cycle at 100 PSI. Charge time is 5 minutes from empty to full. We don't need to empty the system after every match. We would only do so in the times where we needed to. I also checked the rules for that.
Finals Could Be a problem if you have to fix something during that time.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 12-02-2015, 23:00
JohnFogarty's Avatar
Trapped under a pile of Mechanums
AKA: @doctorfogarty
Having been through elims at orlando last year, I think we should be fine. We wouldn't need a full charge to be effective either. The number of actuations we get from a half charge is at the minimum of what we'd need to score around 100+ points by ourselves.
Our goal with this design was extreme simplicity and speed. Come reveal night you should see that we've achieved just that.
John Fogarty
Unread 12-02-2015, 23:31
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Cool - when I looked for Ultimate Ascent (our primary climber actuators were pneumatic, as well as the "trigger" for the frisbee thrower), the only 100% duty cycle compressors I found were significantly larger.
Unread 13-02-2015, 00:04
AKA: @doctorfogarty
I did a search on compressors on CD and found this thread http://www.chiefdelphi.com/forums/sh...d.php?t=129321 easily which had a spreadsheet that gave a lot of useful info that helped us decide on the compressor.
John Fogarty
Unread 13-02-2015, 00:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Inspection will be fun, you get to wait around for the compressor to refill the tank.....
Sounds like a neat robot, hopefully we'll see some video soon!
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
Well done! Tongue in cheek is sorely lacking not only in today's world, but also in FRC
Unread 13-02-2015, 22:12
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
Our team went with an airless robot design. (No compressor or air tanks) early prototypes had pneumatics, but they were voted out.
Unread 25-02-2015, 22:31
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
we may use this as mass air storage for a t-shirt cannon. Could you explain how you set it up
Thanks - Sam
Unread 25-02-2015, 23:21
AKA: @doctorfogarty
Thanks - Sam
The air tank comes with a bronze output fitting. That fitting has two outputs on it one 1/4 NPT port and one 1/8 NPT port where the gauge is normally. We simply plugged the 1/4 NPT output and then put a fitting into the 1/8 NPT output to allow for use with the pneumatic tubing allowed within the rules.
Funny enough. We now use a 7 Gallon Aluminum air tank on our bot.
John Fogarty
Unread 26-02-2015, 10:52
Sperkowsky's Avatar
Alright thanks
