Go to Post ...some of our robots could use a proctologist - Scott Ritchie [more]
Unread 13-02-2015, 00:33
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
pic: 4183 Wooden Swrrrv
Unread 13-02-2015, 00:34
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: 4183 Wooden Swrrrv
I want a video of this driving, please. If that module holds up, that would be really awesome.
EDIT: Is that wooden disc on a bearing, or are you using a wood bearing?
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I hope the gears aren't wood too.
Unread 13-02-2015, 00:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Gears aren't wood, but the chain is
They only have one module, and no code yet that I know of. Just a fun side project to make with the laser cutter.
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
What are you using to support the robot weight?
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 13-02-2015, 00:38
GUI GUI is offline
AKA: Gary
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
The wood disk is a bearing, laser cut edge on laser cut edge with some grease.
Just the steering gears.
There will be a thrust bearing between the top of the module and the top sheet on the housing.
Unread 13-02-2015, 08:14
philso philso is offline
FRC #2587
Can you post pictures showing off the internals too?
This is way cool!
Unread 13-02-2015, 23:13
Unregistered User
AKA: Kevin Forbes
This is way cool!
Here are some pictures of the guts.
We copied the basic geometry from the latest 221 revolution pro and added the lower support similar to wild swerve.
Didn't have any 3/8" hex bearings so we made a 1/2" hex to 3/8" hex shaft.
If other portions of the robot hadn't taken up so much time, I'm sure we would have used it. Unfortunately, there's a lot of negativity on these forums regarding designing a swerve drive in a build season So expectations were slim and we went with omniwheels. This was made in the first 2 weeks with very little effort, maybe 10 hours, while we focused on other prototypes.
