Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
Unread 13-02-2015, 00:06
Fry42guy Fry42guy is offline
fryguy
FRC #3275 (The Regulators)
Fry42guy is an unknown quantity at this point
Encoders and rpm
How do i set the rpms of a motor using an encoder. the encoder is connected to the roborio d i/o, i am using can for the jaguars and programming in java.
Unread 13-02-2015, 00:32
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Encoders and rpm
Wow. What an open question.
The first thing you need to decide is "what is it that you're trying to achieve?" If you're considering an encoder, you should have some goal in mind that isn't easily met by just letting a practiced driver have a proportional joystick.
Unread 13-02-2015, 00:41
fryguy
i have two motors that i want to sync in auto. mode, i have little knowledge of programming encoders. my thoughts, if i can program one wheel to spin at 30 rpm i could just do the same for the other wheel... basically i want to know how to program motor1.setspeed(30rpm); if there is such a thing.
Unread 13-02-2015, 08:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Look at extending PIDSubsystem. There's a lot of info on PIDs at this thread. You could also search CD for "PID" and "Drive" together and check threads. I have never used an encoder on a drive system, but they certainly can be effective.
search CD for PID Drive
One thread found in that search that may be helpful
Unread 13-02-2015, 10:36
Originally Posted by Fry42guy View Post
i have two motors that i want to sync in auto. mode ... program one wheel to spin at 30 rpm ... do the same for the other wheel
Have you considered an alternative approach: program the two motors to make the same number of turns, while remaining synchronized?
Unread 13-02-2015, 10:42
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rakusan2 is an unknown quantity at this point
If you only want to keep the motors in sync and would not mind not knowing the rpm then you can try something like what I have bellow.
PS: I have not yet tried this code so you might want to play with the initial motor values and by how much they are changed
	Encoder leftEncoder = new Encoder(0,1), rightEncoder = new Encoder(2,3);
	Timer time = new Timer();
	Talon motor1 = new Talon(0), motor2 = new Talon(1);
	public void autonomousInit(){
		time.start();
		leftEncoder.reset();
		rightEncoder.reset();
	public void autonomousPeriodic() {
    		if(time.get() < 5){
    			double left=0.8 , right=0.8;
    			int dif = leftEncoder.get()-rightEncoder.get();
    			if (dif>0){
    				left-=0.1;
    				right+=0.1;
    			else if(dif<0){
    				left+=0.1;
    				right-=0.1;
    			motor1.set(left);
    			motor2.set(right);
Unread 13-02-2015, 10:46
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
I have a DriveForDistance method that uses encoders. I'm assuming you're using command based. Think of what you want to do:
1. Clear the current count of the encoders
I recommend you create a method in your driveTrain called clearEncoders():
public void clearEncoder() {
		_leftEncoder.reset();
		_rightEncoder.reset();
While you're in your drive train subsystem, go ahead and create getter methods for your encoders.
public double getRightDistance() {
		return _rightEncoder.getDistance();
In your initialize, you want to clear the encoders.
In your execute, you want to tell the motors to go the appropriate direction that the robot should be moving.
In your isFinished:
// code from Joe 2729
double left = Robot._driveTrain.getLeftDistance();
    	double right = Robot._driveTrain.getRightDistance();
    	double distance = Math.abs(left) > Math.abs(right) ? left : right;
    	if(_forw) {
    		return distance >= _distance;
    	} else {
    		return distance <= _distance;
That's how the general layout of your program should be if you want to drive for a distance.
Unread 13-02-2015, 12:37
Let's say you want to go from position P=0 to P=Pf in autonomous
Ideally, you'd want your control algorithm to do something like this:
1) ramp the speed up vs time (to limit acceleration to an acceptable level to avoid wheel slip or excessive rocking of the vehicle) until the desired top speed is reached, then hold that speed until you are within distance L of the desired stopping point (i.e. P=Pf-L).
2) then ramp the speed down as a function of L (to avoid excessive deceleration), so that speed=0 when L=0 (i.e P=Pf).
3) all the while keeping the encoder counts synchronized between the left and right motors
