Go to Post The game is going to be exciting. I want a front row seat and a big box of buttered popcorn. - JaneYoung [more]
Unread 13-02-2015, 11:02
fireXtract fireXtract is offline
MegaHertz_Lux
FRC #2847 (Mega Hertz)
fireXtract is an unknown quantity at this point
Re: Using Hall Effect Sensors
Now i'm able to get the elevator to stop in response to the hall effect sensor, but once it use it to go up i cant press it to go up again, and if i go down i can only go down once. Pressing the button multiple times to add to count does nothing. What am i missing here?
package org.usfirst.frc.team2847.robot.commands;
import org.usfirst.frc.team2847.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class MagicElevator extends Command {
	int count;
	int tcount;
	double go;
	boolean done;
	public MagicElevator(int setpoint) {
		// Use requires() here to declare subsystem dependencies
		requires(Robot.elevator);
		tcount = setpoint;
	// Called just before this Command runs the first time
	protected void initialize() {
		System.out.println(this);
	// Called repeatedly when this Command is scheduled to run
	protected void execute() {
		count = count + tcount;
		if (count > 0 && Robot.elevator.isHallSet()) {
			count = (count - 1);
		} else if (count < 0 && Robot.elevator.isHallSet()) {
			count = (count + 1);
		if (count >= 1) {
			go = 1;
		} else if (count <= -1) {
			go = -1;
		Robot.elevator.torro(go);
		if (count != 0) {
			done = false;
		} else if (count == 0) {
			done = true;
		tcount = 0;
		SmartDashboard.putNumber("whaeva", count);
		SmartDashboard.putBoolean("hall", Robot.elevator.isHallSet());
	// Make this return true when this Command no longer needs to run execute()
	protected boolean isFinished() {
		SmartDashboard.putNumber("finsishsjdfiaopsdfsa", count);
		return done;
	// Called once after isFinished returns true
	protected void end() {
		Robot.elevator.nothing();
	// Called when another command which requires one or more of the same
	// subsystems is scheduled to run
	protected void interrupted() {
		end();
