Re: Problem running Eclipse Code
Eclipse DOES look at JAVA_HOME; we had this same issue in the past, fixed our home variable, and everything has worked fine since.
which states "Eclipse DOES NOT consult the JAVA_HOME environment variable." |
Yes since Eclipse has its own path for JAVA_HOME and that is located in the preferences
I'm outta here. |
Sorry I have just installed Eclipse on a new computer and found out that both methods work so go with with what ever you find the best |
