Go to Post Honestly I'm looking forward to just seeing all my friends again, that's what FIRST is really about to me. - Barry Bonzack [more]
Unread 13-02-2015, 12:12
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rakusan2 is an unknown quantity at this point
Re: Problem running Eclipse Code
Originally Posted by Oromus View Post
Eclipse DOES look at JAVA_HOME; we had this same issue in the past, fixed our home variable, and everything has worked fine since.
Then that is strange since for our team that did not work and as a reason I have been shown this site https://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F
which states "Eclipse DOES NOT consult the JAVA_HOME environment variable."
Unread 13-02-2015, 12:15
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
The error message itself shows that the build failed and suggested the JAVA_HOME variable may need to be corrected. *shrug*
Unread 13-02-2015, 12:21
AKA: Tomas Rakusan
Yes since Eclipse has its own path for JAVA_HOME and that is located in the preferences
Unread 13-02-2015, 12:27
Oromus's Avatar
AKA: Ryan
Not entirely correct, since we fixed our problem by correcting our actual JAVA_HOME variable. Anyways, I think we've debated this enough I'm outta here.
Unread 13-02-2015, 14:05
AKA: Tomas Rakusan
Sorry I have just installed Eclipse on a new computer and found out that both methods work so go with with what ever you find the best
