Go to Post Take what you have learned, build on it and share it. Others will do the same. Enjoy the journey. - Bertman [more]
Unread 12-02-2015, 22:26
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Industrial switch
Originally Posted by SousVide View Post
.. Is this about the NC wired switch ? not sure if this was something else in the thread that could be a software change ...
How would a software solution work to detect a open-wire condition in a normally NO switch ?
This web page
covers the difference between NO and NC pretty well. It's based on the 2014 control system, but I don't think any of the concepts at this level of detail have changed.
Unread 13-02-2015, 00:34
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Originally Posted by GeeTwo View Post
This web page
Here is the 2015 version. The only "change" is the picture of the switch is slightly brighter.
One thing to point out (and I edited my post saying I assumed wrong), is that the digital input on the roboRIO will be 1 when the switch is open, and 0 when it is closed.
Example Java code is provided in the link, and the code will be the same for C++.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 13-02-2015, 00:54
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
So, the problem that we've always have is having the limit-switches wired in a way that is failsafe. If the mechanism or action that the limit-switch is meant to stop is one that could be destructive or harmful, then if somehow the limit-switch itself fails or the wiring connecting it to the RoboRio fails (cut or is disconnected), the software won't read this limit condition and the destructive process will proceed... In this case, we like to use limit-switch that are wired as NC (and open when contact is made)... that way, if there's a failure in the limit-switch (or the wiring) it stops the mechanism from working altogether.
I don't think there's a way for a NO limit-switch to be fixed in software to detect a limit-switch failure scenario. It would look like everything is fine until when it's suppose to signal the contact.
Unread 13-02-2015, 07:59
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
As mentioned before Automation Direct literally has industrial grade switches. Many of them have wires for both N.O. and N.C. Operation at the same time so if you wanted to tell if the switch wasn't connected you would know for sure if both N.O. and N.C. were off at the same time. And Automation Direct gave everyone a voucher for $30 and one switch runs for $24 - $28 depending on what kind.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 13-02-2015, 08:16
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Automation Direct.
AAP2T51Z11
$14.50 each
Limit Switch style with adjustable arm.
We are using these for overtravels on our elevator.
Plastic body means they are light as compared to other industrial switches.
The sooner we get behind schedule, the more time we have to catch up.
Unread 13-02-2015, 12:22
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
As Al mentioned, overtravel is very important when you're slinging big masses. I recommend industrial limit switches, rather than push buttons (which are meant for humans to press, not machines). Something like this: http://www.mcmaster.com/#7988k2/=vw63cb
