Go to Post Cant get hair and nails done and still run a robot. - wendymom [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 08-03-2003, 18:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
DHTML Problem
I have a page where I want to implement a DHTML Navigation Bar and a DHTML Countdown Script. Each script works great separately but when both are in the same html file, the first one (nav bar) doesn't work. Any ideas?
Unread 08-03-2003, 19:42
Umm Errr...
we ll you really haven't told us enough to help. could you post your code?
1139 Alumni
Unread 08-03-2003, 21:30
You can see what the Nav Bar is supposed to look like at www.team696.org/navhome.html (not all the links in the bar work yet) I took out the countdown to make this work.
The code for the page with both scripts is too long to post so here is an attatched txt file.
Unread 08-03-2003, 21:47
Umm Errr...
comment out the line:
window.onload=start_countdown
add the lines:
<script type='text/javascript'>
start_countdown()
</script>
like such:
1139 Alumni
Unread 08-03-2003, 21:57
Nifty. Thanks a bundle.
<edit> And I guess because the counter now loads last, the page seems to load faster. Thanks</edit>
-sanddrag
And for anyone else who reads this, what happened in this thread was the kind of speedy, quality assistance that every FIRST-er is willing to give. Now THAT, is gracious professionalism.
Unread 11-03-2003, 20:08
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I haven't yet looked through your code, but I'd speculate that the problem was that both scripts required a function to be assigned to window.onload so that the function will be called when the browser has finished loading the page. When the second one is assigned to window.onload it overwrites the first one. This is normal browser behaviour and can also be solved by adding an onload element to your body attribute with the two onloads seperated by semicolons:
onload= "scriptOne();scriptTwo()"
So there's another solution. If I diagnosed the problem right. Maybe I'll actually look a the code if I get time.
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
