| Thread Tools |
Rating:
Display Modes |
the code runs but when it comes to pressing the buttons nothing happens
package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.IterativeRobot; import edu.wpi.first.wpilibj.Jaguar; import edu.wpi.first.wpilibj.buttons.JoystickButton; import edu.wpi.first.wpilibj.buttons.Button; import edu.wpi.first.wpilibj.Joystick; import edu.wpi.first.wpilibj.RobotDrive; import edu.wpi.first.wpilibj.livewindow.LiveWindow; /** * The VM is configured to automatically run this class, and to call the * functions corresponding to each mode, as described in the IterativeRobot * documentation. If you change the name of this class or the package after * creating this project, you must also update the manifest file in the resource * directory. */ public class Robot extends IterativeRobot { RobotDrive Drive; Joystick drivestick; Joystick joystick; int autoLoopCounter; /** * This function is run when the robot is first started up and should be * used for any initialization code. */ public void robotInit() { Jaguar FL = new Jaguar (5); Jaguar BL = new Jaguar (2); Jaguar FR = new Jaguar (3); Jaguar BR = new Jaguar (4); Drive = new RobotDrive(FL,BL,FR,BR); drivestick = new Joystick(0); joystick = new Joystick(1); } /** * This function is run once each time the robot enters autonomous mode */ public void autonomousInit() { autoLoopCounter = 0; } /** * This function is called periodically during autonomous */ public void autonomousPeriodic() { /*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds) { Drive.drive(-0.5, 0.0); // drive forwards half speed autoLoopCounter++; } else { Drive.drive(0.0, 0.0); // stop robot } */ } /** * This function is called once each time the robot enters tele-operated mode */ public void teleopInit(){ } /** * This function is called periodically during operator control */ public void teleopPeriodic() { Drive.arcadeDrive(drivestick); Button button1 = new JoystickButton(joystick, 1), button2 = new JoystickButton(joystick, 2), button3 = new JoystickButton(joystick, 3), button4 = new JoystickButton(joystick, 4), button5 = new JoystickButton(joystick, 5), button6 = new JoystickButton(joystick, 6), button7 = new JoystickButton(joystick, 7), button8 = new JoystickButton(joystick, 8), button9 = new JoystickButton(joystick, 9), button10 = new JoystickButton(joystick, 10), button11 = new JoystickButton(joystick , 11); button1.whenPressed(new ElevatorOff()); button2.whenPressed(new ElevatorOn()); button3.whenPressed(new ElevatorReverse()); button4.whenPressed(new ArmsOut()); button5.whenPressed(new ArmsIn()); button6.whenPressed(new ArmsVerticalIn()); button7.whenPressed(new ArmsVarticalOut()); button8.whenPressed(new BlueLightShow()); button9.whenPressed(new LigthShowOn()); button10.whenPressed(new RedLightShow()); button11.whenPressed(new LightShowEnd()); } /** * This function is called periodically during test mode */ public void testPeriodic() { LiveWindow.run(); } } Last edited by AnnaliseDonavan : 13-02-2015 at 12:58. |
Re: Code problem
Based on the block of code below, i feel its safe to assume that you have differnt classes for all of the commands you wish to run once the button is pressed, and it would be easier to diagnose if you posted your full robot code.
If this is infact your only class, your attempting to refernce a null command, so the button press is trying to reach a null comand, in result doing nothing. Quote:
Re: Code problem
import edu.wpi.first.wpilibj.Talon; import edu.wpi.first.wpilibj.command.Command; public class ArmsIn extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { Talon LeftArm = new Talon(9); Talon RightArm = new Talon(8); LeftArm.set(1); RightArm.set(-1); try { Thread.sleep(500); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } LeftArm.set(0); RightArm.set(0); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Talon; import edu.wpi.first.wpilibj.command.Command; public class ArmsOut extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { Talon RightArm = new Talon(9); Talon LeftArm = new Talon(8); LeftArm.set(-1); RightArm.set(1); try { Thread.sleep(500); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } LeftArm.set(0); RightArm.set(0); // TODO Auto-generated method stub } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Talon; import edu.wpi.first.wpilibj.command.Command; public class ArmsVarticalOut extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { Talon In_Out = new Talon(7); Talon In__Out = new Talon(0); In_Out.set(-1); In__Out.set(-1); try { Thread.sleep(500); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } In_Out.set(0); In__Out.set(0); // TODO Auto-generated method stub } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Talon; import edu.wpi.first.wpilibj.command.Command; public class ArmsVerticalIn extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { Talon In_Out = new Talon (7); Talon In__Out = new Talon(0); In_Out.set(1); In__Out.set(1); try { Thread.sleep(500); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } In_Out.set(0); In__Out.set(0); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Relay; import edu.wpi.first.wpilibj.command.Command; public class BlueLightShow extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Relay relay1 = new Relay(0); Relay relay2 = new Relay(1); relay1.set(Relay.Value.kOn); relay2.set(Relay.Value.kOff); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Jaguar; import edu.wpi.first.wpilibj.command.Command; public class ElevatorOff extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Jaguar Elevator1 = new Jaguar(5); Jaguar Elevator2 = new Jaguar(0); Elevator1.set(0); Elevator2.set(0); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Jaguar; import edu.wpi.first.wpilibj.command.Command; public class ElevatorOn extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Jaguar Elevator1 = new Jaguar(5); Jaguar Elevator2 = new Jaguar(0); Elevator1.set(.25); Elevator2.set(.25); } @Override protected boolean isFinished() { return false; } @Override protected void end() { } @Override protected void interrupted() { } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Jaguar; import edu.wpi.first.wpilibj.command.Command; public class ElevatorReverse extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Jaguar Elevator1 = new Jaguar(5); Jaguar Elevator2 = new Jaguar(0); Elevator1.set(-.25); Elevator2.set(-.25); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Relay; import edu.wpi.first.wpilibj.command.Command; public class LightShowEnd extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Relay relay1 = new Relay(0); Relay relay2 = new Relay(1); relay1.set(Relay.Value.kOff); relay2.set(Relay.Value.kOff); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Relay; import edu.wpi.first.wpilibj.command.Command; public class LigthShowOn extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Relay relay1 = new Relay(0); Relay relay2 = new Relay(1); relay1.set(Relay.Value.kReverse); relay2.set(Relay.Value.kOn); try { Thread.sleep(5000); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } //Turn on lights Blue and Green) relay1.set(Relay.Value.kOn); relay2.set(Relay.Value.kReverse); try { Thread.sleep(5000); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } // Turns on blue and red lights relay1.set(Relay.Value.kOn); relay2.set(Relay.Value.kForward); try { Thread.sleep(5000); //stop for 1/2 second } catch(InterruptedException ex) { // allows for interruption of the sleep period Thread.currentThread().interrupt(); } relay1.set(Relay.Value.kReverse); relay2.set(Relay.Value.kOn); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.Relay; import edu.wpi.first.wpilibj.command.Command; public class RedLightShow extends Command { @Override protected void initialize() { // TODO Auto-generated method stub } @Override protected void execute() { // TODO Auto-generated method stub Relay relay1 = new Relay(0); Relay relay2 = new Relay(1); relay2.set(Relay.Value.kForward); relay1.set(Relay.Value.kReverse); } @Override protected boolean isFinished() { // TODO Auto-generated method stub return false; } @Override protected void end() { // TODO Auto-generated method stub } @Override protected void interrupted() { // TODO Auto-generated method stub } } |
