Go to Post No, no, no, it's a fire game. The pool is there in case of accidents. - artdutra04 [more]
Unread 13-02-2015, 13:41
ChaFla ChaFla is offline
FRC #0834
ChaFla is an unknown quantity at this point
Where is image20.jpeg?
We've looked everywhere for at least a couple (sad) hours and still can't find it. It's referred to in the wpilib sample project for vision/color tracking (2015 Vision Color Sample). Has anyone been able to find it?
Edit: If someone could even just throw it on imgur, that'd work.
Edit 2: Never mind! We found it in the wpilib git, but never managed to find it anywhere else, so problem solved!
Unread 13-02-2015, 14:28
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Where is image20.jpeg?
Did you try: C:\Program Files (x86)\National Instruments\LabVIEW 2014\examples\FRC\roboRIO\Vision\2015 Vision Example\Sample Images
If you are looking at the LabVIEW example, the default path is something like:
"Sample Images\Some Name"
Remove the second part so the path is just "Sample Images" and run it.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 13-02-2015, 14:37
FRC #0834
We are doing it with eclipse, can you show us where to download the LabView files?
Unread 13-02-2015, 15:21
wt200999's Avatar
Texas Instruments
AKA: Will Toth
Well in that case:
http://www.chiefdelphi.com/forums/sh...d.php?t=133075
Unread 14-02-2015, 15:06
5048Programmer 5048Programmer is offline
FRC #5048 (Spartronics)
5048Programmer is an unknown quantity at this point
Seems if you just install LabView by itself you get all the pictures.
Here's an imgur album of all of the sample pictures: https://imgur.com/a/JKPnu They're in order, so #20 is the 20th picture (the one with a single tote and can)
EDIT: Or you can check the link above. That works too.
