Go to Post Even though others have had success, I will be honest, this method sort of creeps me out. - Joe Johnson [more]
Unread 13-02-2015, 14:34
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Re: Some thoughts about Double Precision numbers
I'll just say, as the poster of the "if (distance != 6)" line, that I wrote it with the fact that unless the double is exactly 6 that it will run in mind. That's because it led to a PID loop that contained a double-based deadzone, so I didn't write see the point in writing a deadzone for 6 when the PID already had a deadzone.
Unread 13-02-2015, 16:18
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Hi Oromus-- in retrospect I suppose I shouldn't have used exactly your line to start the new thread. Apologies about that.
But I do see red flags whenever I see code that compares doubles for equality or inequality. I thought I'd post what I believe to be a very good rule of thumb about floating point numbers. Maybe some will disagree with my take and a nice discussion will erupt. Otherwise, perhaps folks will look at comparisons of floating point numbers a bit more carefully and code better robots as a result.
I don't really agree with your assertions above, but this thread isn't the place for that discussion, so maybe I'll send you a PM about my thoughts. I still think that should have been a red flag for you, but probably for entirely different reasons than you suspect.
Unread 31-03-2015, 19:45
ShortCircuit908's Avatar
ShortCircuit908 ShortCircuit908 is offline
King of Hacky Fixes
AKA: Caleb Milligan
FRC #4450 (Olympia Robotics Federation)
ShortCircuit908 is an unknown quantity at this point
Implementing a range is the "correct" way to do it, but not the only way. Another option is to cast the double value to an int, or using Math.round(distance). This would strip the trailing decimal places on the double.
Both
int compare_distance = (int)distance;
if(compare_distance != 6){
    //Covers values from 6.0 to 6.999...
and
if(Math.round(distance) != 6){
    //Covers values from 5.5 to 6.4999...
will work equally well in most cases.
Unread 31-03-2015, 19:55
Jared Russell's Avatar
Taking a year (mostly) off
This is why the gcc compiler has a -Wfloat-equal warning flag. Using the "==" operator on floating point types usually indicates a programmer mistake.
