Go to Post I believe youth is contagious. I want to catch as much as I can! - Al Skierkiewicz [more]
Unread 13-02-2015, 14:39
Hawk_Prime Hawk_Prime is offline
FRC #3229
Hawk_Prime is an unknown quantity at this point
Angry Problems with imported code?
Hey, I have my teams robot code on my computer, and when I try to give it to other team members, it gives this error:
Has anyone else had this problem and is there any way to fix it?
Unread 13-02-2015, 14:58
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liaison
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Re: Problems with imported code?
Your image appears to be broken. Can you either supply a new link or perhaps type out the error?
Unread 13-02-2015, 15:05
FRC #3229
Here's the error he is getting
C:\Users\Matteo Longo\wpilib\java\current\ant\build.xml:12: classloader doesn't support the "loader" attribute
Unread 13-02-2015, 15:09
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Make a new project and copy all the code oveyapyap shouldn't take more then more then 5 minutes
Unread 13-02-2015, 15:10
Oromus's Avatar
AKA: Ryan
Questions:
Is this error is being given when your friend tries to push code to the robot?
Is there any other errors, either in the code or when you're pushing code?
Is your friend using Eclipse?
Does your friend have the WPI plugins?
Unread 13-02-2015, 15:20
FRC #3229
Yes, no, yes, yes
Unread 13-02-2015, 15:44
Oromus's Avatar
AKA: Ryan
How did you transfer the files to your friend's computer (i.e. USB drive, Github, magic, ect...)?
Unread 13-02-2015, 15:53
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rakusan2 is an unknown quantity at this point
Did your friend create his own project before you shared your project with him? Since for my team for some reason all computers that we transferred the code to required us to create an FRC project which we deleted right after it was created for our shared code to not show any errors
Unread 23-01-2016, 19:47
Wasabi Fan Wasabi Fan is offline
FRC #0488
Wasabi Fan is an unknown quantity at this point
Did you find a solution to this issue? I'm seeing the same error in my custom build scripts and can't figure out where this error is coming from.
Unread 06-02-2016, 17:50
Spaghetti's Avatar
Spaghetti Spaghetti is offline
FRC #0488 (XBot)
Spaghetti is an unknown quantity at this point
It looks like this problem happens with ant 1.8.2 but works fine with ant 1.9+.
Unread 06-02-2016, 23:58
FRC #0488
For future reference, the problem actually turned out to be that the jars that wpilib puts in "<USER FOLDER>/wpilib/java" weren't available. Adding those fixed the issue.
