Go to Post If it's not a sport, and it's not an art, it might as well be criminal behavior, because that's how you're going to be treated. - jasoni [more]
Unread 13-02-2015, 10:09
Team 4939 Team 4939 is offline
AKA: Anshul Shah
FRC #4939 (All spark 9)
Team 4939 is an unknown quantity at this point
Pneumatics Programming
Hello,
I was just adding the pneumatics code required, and being the rookie I am , I came up with an error. The thing is that I used the code from http://wpilib.screenstepslive.com/s/...for-pneumatics exactly(or so I think) and there seems to be an error. The error message is: Syntax error, insert "AssignmentOperator Expression" to complete Expression. I have posted the code below:
package org.usfirst.frc.team4939.robot;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	RobotDrive myRobot;
	Joystick stick;
	int autoLoopCounter;
	Victor victor;
	Compressor c;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
    	myRobot = new RobotDrive(0,1,2,3);
    	stick = new Joystick(0);
    	victor = new Victor(4);
    	c = new Compressor(0);
    	c->SetClosedLoopControl(true); // THIS SEEMS TO BE THE PROBLEM
     * This function is run once each time the robot enters autonomous mode
    public void autonomousInit() {
    	autoLoopCounter = 0;
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
    	if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
			myRobot.drive(-0.5, 0.0); 	// drive forwards half speed
			autoLoopCounter++;
			} else {
			myRobot.drive(0.0, 0.0); 	// stop robot
     * This function is called once each time the robot enters tele-operated mode
    public void teleopInit(){
     * This function is called periodically during operator control
    public void teleopPeriodic() {
    	double rot = -stick.getX();
    	double speed = -stick.getY();
        myRobot.arcadeDrive(speed,rot);
        if(stick.getRawButton(3)){
        	victor.set(1);
        else if(stick.getRawButton(2)){
        	victor.set(-1);
        else{
        	victor.set(0);
        ArmsDouble= new DoubleSolenoid(1, 2);
        ArmsDouble= new DoubleSolenoid(1, 1, 2);
        if(stick.getRawButton(4)){
        	ArmsDouble.set(DoubleSolenid.Value.kForward);
        else if(stick.getRawButton(5)){
        	ArmsDouble.set(DoubleSolenoid.Value.kReverse);
     * This function is called periodically during test mode
    public void testPeriodic() {
    	LiveWindow.run();
Thanks to all in advance.
Unread 13-02-2015, 10:29
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liaison
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Re: Pneumatics Programming
Change this...
...to this...
c.setClosedLoopControl(true);
The "->" needs to be a "." and "Set" needs to become "set". That WPILib example is not showing the code in Java syntax. Also, for future reference, starting this year you don't have to create a Compressor object or do anything with it; if you make any pnuematics-related classes (i.e. Solenoids), the compressor turns on and regulates itself without any code needed. Also, that link appears to be a 2014 code example; you may want to look at 2015 code examples here instead. Good luck with programming!
Unread 13-02-2015, 10:50
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
As Oromus said, that example is in C++. All you're doing is calling a function -- inside the Compressor object there is a function called setClosedLoopControl that takes a boolean as an argument. In Java, that would be articulated as...
...while in C++ that would be:
They both do the same thing; they're just differences between languages. It's like comparing apples to oranges -- they both can achieve the same thing (making you less hungry) but the means of doing so is relatively different.
that was a horrible example imsosorry
Unread 13-02-2015, 15:20
AKA: Anshul Shah
Originally Posted by Oromus View Post
Change this...
...to this...
Thank You, very much that seems to have fixed my problem.
Unread 13-02-2015, 15:22
AKA: Anshul Shah
import edu.wpi.first.wpilibj.DoubleSolenoid;
 * directory.
	RobotDrive myRobot;
	Joystick stick;
	Victor victor;
	Compressor c;
			autoLoopCounter++;
			} else {
        	victor.set(1);
        	victor.set(-1);
        else{
        	victor.set(0);
        ArmsDouble= new DoubleSolenoid(1, 2); // THATS SEEMS TO BE THE PROBLEM
        ArmsDouble= new DoubleSolenoid(1, 1, 2);// THAT SEEMS TO BE THE PROBLEM
        	ArmsDouble.set(DoubleSolenoid.Value.kForward);
    	LiveWindow.run();
I seem to have a different problem now.
The error code that shows up is: Multiple markers at this line
- DoubleSolenoid cannot be resolved
to a type
- ArmsDouble cannot be resolved to a
variable
Thank You
Unread 13-02-2015, 15:34
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rakusan2 is an unknown quantity at this point
Originally Posted by Team 4939 View Post
 * directory.
	RobotDrive myRobot;
	Joystick stick;
	Victor victor;
	Compressor c;
			autoLoopCounter++;
			} else {
        	victor.set(1);
        	victor.set(-1);
        else{
        	victor.set(0);
    	LiveWindow.run();
to a type
variable
Thank You
You need a declaration for ArmsDouble
DoubleSolenoid ArmsDouble;
also why are you initializing ArmsDouble twice?
Unread 13-02-2015, 15:39
Oromus's Avatar
AKA: Ryan
As Rakusan2 said, you need to declare ArmsDouble somewhere, i.e. "DoubleSolenoid ArmsDouble = new DoubleSolenoid(1, 2)". DoubleSolenoid not being able to resolved may be fixed by that as well.
Unread 13-02-2015, 15:42
AKA: Anshul Shah
If I am using a Double Solenoid do I not need to initialize it twice for both the In and Out feature?
That's the impression this gave me: http://wpilib.screenstepslive.com/s/...ders-solenoids
Unread 13-02-2015, 15:46
AKA: Tomas Rakusan
No, a single declaration and initialization of DoubleSolenoid takes care of both solenoids
Oromus's Avatar
AKA: Ryan
That example was just showing the different ways you can initialize your DoubleSolenoid; you do one constructor or the other.
Unread 15-02-2015, 00:38
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
DoubleSolenoid(in channel, out channel). Also, the compressor does not need to be instantiated. The compressor is on a closed loop controlled by the PCM. You just need to instantiate the DoubleSolenoid once, and and set the position on button values.
