Go to Post Gotta love the blurred robots :cool: - Steven Donow [more]
Unread 13-02-2015, 15:48
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Straffing Issue
Okay so everything is working. Currently the left joyx on our XBox controller is straffing and the left joyy on the controller is forwards/backwards. The straffing is inverted - if I push the joystick left it goes right and vice versa. Also it is REALLY slow while straffing. The mecanumDrive function is in the subsystem Mecanum and the values are passed to it in the DriveTele command
I inverted the values already because at first forwards/backwards was inverted and straffing was good - but when I inverted it forwards/backwards was right and straffing was inverted
Does anyone have any ideas on how to invert the straffing and increase its speed?
Here is the code: https://github.com/MrSTUDofCODE/NewM...team4623/robot
THANKS!
Unread 13-02-2015, 16:09
Re: Straffing Issue
If everything is working properly except for the left/right reversal of strafing, then negate your joystick X axis before using it.
Unread 13-02-2015, 16:12
Re: Straffing Issue
this is symptomatic of poor roller adjustment (high roller spinning friction).
check every single one of the rollers on each of the four wheels to make sure they spin freely.
Unread 13-02-2015, 17:04
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Re: Straffing Issue
THANKS!
Here is what your command sends to mecanumDrive from your DriveTele command:
    	Robot.mec.mecanumDrive(
                (oi.stick.getLeftJoyX()+oi.stick.getLeftJoyY())/2,
                (oi.stick.getLeftJoyY()-oi.stick.getLeftJoyX())/2,
                -(oi.stick.getLeftJoyY()-oi.stick.getLeftJoyX())/2,
                -(oi.stick.getLeftJoyX()+oi.stick.getLeftJoyY())/2);
this in turn calls:
   public void mecanumDrive(double FL, double RL, double FR, double RR)   {
        frontLeftMotor.set(-FL);
        rearLeftMotor.set(-RL);
        frontRightMotor.set(-FR);
        rearRightMotor.set(-RR);
at first glance it is obvious that even if oi.stick.getLeftJoyX() is 1.0 and your Y is 0.0, a pure strafe is going to genrate 0.5 for all motors (probably your slowness problem).
In the case of strafe right, X will be 1.0 so your 4 values become
FL=0.5
RL=-0.5
FR=+0.5
RR=-0.5
You then negate all of these for the motors so the motors see
frontLeft -0.5
rearLeft +0.5
frontRight -0.5
rearRight +0.5
Because those on the right side are likely driving in reverse on positive voltage this is most likely
frontLeft toward robot rear 0.5
rearLeft toward robot fore 0.5
frontRight toward robot fore 0.5
rearRight toward robot rear 0.5
which unfortunately is the way to rotate wheels for strafing left.
So as Ether says, change the +/- in front of all your getX() calls in your DriveTele and this will solve the problem.
To fix your speed issue you need to do something different than (X + Y)/2.0.
(X+Y)/2.0 gives you 1.0 only on the diagonals, but not straight ahead or to the sides.
If you have studied polar math in school, you should know that a better formulation for what you are trying to do is to combine the two into a magnitude with sqrt(x*x + y*y) via the Pythagorean theorem. This way straight left calculates sqrt(1+0) = 1.0. And sqrt(0.5*0.5 + 0.5*0.5) = 0.5. But then to get your signs right, you have to compensate. based on the sign of x and y.
I would recommend that you instantiate a RobotDrive object in your subsystem and call the mecanumDrive_Cartesian(x,y,rot,gyro) function-- you can pass 0 in for rotation and the gyro. Then you can just pass getX and getY from your stick.
public class Mecanum extends Subsystem {
    SpeedController frontLeftMotor = new Jaguar(0);
    SpeedController frontRightMotor = new Jaguar(1);
    SpeedController rearLeftMotor = new Talon(2);
    SpeedController rearRightMotor = new Jaguar(3);
    RobotDrive myDrive;
   public Mecanum() {
        //Constructor-- called when we do new Mecanum() in Robot
        myDrive=new RobotDrive(frontLeftMotor,rearLeftMotor,
                               frontRightMotor,rearRightMotor);
    public void mecanumViaRobotDrive(double x, double y, double rotation, double gyro)
         myDrive.mecanumDrive_Cartesian(x,y,rotation,gyro);
Then in DriveTele
public void execute() {
    Robot.mec.mecanumViaRobotDrive(oi.stick.getLeftJoyX(),oi.stick.getLeftJoyY(),0,0);
Good luck!
Unread 15-02-2015, 00:47
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Yeah, just negate the axis values you are using to strafe. Also, strafing requires more torque than moving normally, so its normal to be moving more slowly. If you want to move more effectively sideways, then gear your drivetrain for torque.
Unread 18-02-2015, 12:13
LFRobotics's Avatar
FRC #4623
Re: Straffing Issue
Okay I that fixed the straffing inverted issue but it still does not go faster with cartesian - and if I try multiplying the values everything gets screwed up
Unread 18-02-2015, 12:35
Re: Straffing Issue
Did you do this yet?
Unread 18-02-2015, 14:53
Programming Mentor
AKA: Craig Stelter
Re: Straffing Issue
Have you tried using RobotDrive?
I looked at your Github code which was updated about 24 hours ago and it still looks like you are sending 0.5 power to all your motors while strafing.
