Go to Post If this thread isn't a sign that CD is going through some serious withdrawals, I don't know what is. - Ty Tremblay [more]
Unread 13-02-2015, 16:09
bharrison6 bharrison6 is offline
FRC #3843
bharrison6 is on a distinguished road
Maximum Input Frequency
I am looking to get a new quadrature encoder to work for our shafts which spin around 5k rpm or so. I need to know the ppr to order. In order to do that I need to know the maximum input frequency of the robo rio.
Thanks in advance,
Bryant
Unread 13-02-2015, 16:17
FRC #3843
Re: Maximum Input Frequency
actually I need it of the tallon srx because that is want is decoding the signal
Unread 13-02-2015, 17:36
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Checkout the electrical specs in Talon SRX User's Guide. Based on your RPM, you should be able to calc the max CPR (not PPR).
I think you'll find though that there is no practical limitation on what encoder you can choose.
Unread 13-02-2015, 17:37
The SRX decodes the quadrature encoders in hardware.
Max RPM is 80million/CPR (CPR=Cycles Per Rev).
