Go to Post Side effect include: Hearing loss, splinters, blisters, extreme sprit, uncontrollable urges to scream "GO MOE", and bright green fashion sense - The Lucas [more]
Unread 13-02-2015, 09:34
DarkSpartan117 DarkSpartan117 is offline
FRC #0079 (Krunch)
DarkSpartan117 is an unknown quantity at this point
pic: Team 79 Teaser's
Unread 13-02-2015, 09:35
Joining the 900 Meme Team
FRC #0079
Re: pic: Team 79 Teaser's
Ugh, that wiring though. I'm going to enjoy making fun of Tom if that's the final wiring job.
Unread 13-02-2015, 09:42
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Originally Posted by DarkSpartan117 View Post
Looks terrific... however, not sure those numbers satisfy numbering requirements, so you might need to have others as well, (maybe you already know this and do have others.)
Need to be black on white (not black on transparent) and 1" of white all around the perimeter of the black number set.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 13-02-2015, 10:26
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Neat looking numbers, but unfortunately they do not meet the number display rules to my best judgement, so unfortunately you'll need additional numbers to meet the requirements.
Originally Posted by Section 4-R2
Team numbers must be displayed on the ROBOT and meet
the following criteria:
A. consist of numerals at least 3.5 in. high, at least 0.5 in. in stroke width,
and be black in color with a white background extending at least 1 in.
from the edges of the numbering,
Hope this helps!
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 13-02-2015, 10:34
You should consider removing those wooden blocks from the underside of your frame so that wheels have greater friction with the floor-- It will improve your drive velocity tremendously
John Vriezen
Unread 13-02-2015, 11:47
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
That looks awesome! We are looking forward to seeing you guys in a few short weeks!
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 13-02-2015, 11:54
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Can't tell because of the lights, but I wonder if the plastic background were frosted white(which it might be) would it satisfy the requirements. Because when off it would be white. Not sure if it has enough of a border.
Unread 13-02-2015, 12:28
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Maybe they have a number that meets the requirement that isn't shown in this teaser photo... If not, I suggest that they remedy that before inspection.
Unread 13-02-2015, 12:44
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
It's really not out of the realm of possibility to make plates that show an actual team's logo at a size as big or larger than the official numbering requirements, as well as meeting the required numbering system. I have heard some teams are doing that and it wouldn't really surprise me to see robots with giant team logos complemented by number plates as small as legally possible.
Unread 13-02-2015, 12:51
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I can't see any speed controllers in your picture. You can't just wire the motors directly to the PDB. There are rules about that.
Also, this year's game features totes, recycling containers, and litter (pool noodles). I don't see any way for the robot shown in your picture to be able to manipulate these things. Perhaps you might want to design for that.
Hi!
Unread 13-02-2015, 12:56
sodizzle's Avatar
sodizzle sodizzle is offline
AKA: Brandon Sidoti
FRC #1023 (Bedford Express)
sodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the rough
Gotta look a bit harder, but I spotted some motor controllers.
Proud alumni of 1023
http://www.chiefdelphi.com/forums/ximage.php,qtype=sigpic,auserid=64794,adateline=13  93953662.pagespeed.ic._coysrOV9p.jpg
Unread 13-02-2015, 13:08
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
If you can't visibly see it in the teaser, it's not on the robot. Everyone knows that.
Unread 13-02-2015, 13:43
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
I love how the numbers are back-lit!
Unread 13-02-2015, 16:29
hunterteam3476's Avatar
hunterteam3476 hunterteam3476 is offline
AKA: Hunter
FRC #3476 (Code Orange)
hunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud of
I'm loving the LED background!
http://www.TeamCodeOrange.com
2015 - Championship - Tesla Champions, #2 pick
2015 - San Diego - Regional Chairman's Award, #1 Pick, Finalists
2015 - Inland Empire - Engineering Inspiration Award, #2 Pick, Finalists
2014 - Championship, Excellence In Engineering Award
2014 - Las Vegas- #3 pick, Finalists
2014 - San Diego - Regional Chairman's Award, Regional Imagery, #2 Alliance Captain, Semi Finalists
2013 - Championship - Newton Champions, #3 pick
2013 - Inland Empire - Innovation in Control Award, #2 Alliance Captain, Finalists
2013 - San Diego - Industrial Design Award, #4 Pick, Semi-Finalists
2012 - San Diego -Regional Winner, Excellence In Engineering Award
2011 - San Diego - Judges Award
Unread 14-02-2015, 20:47
FRC #0079 (Krunch)
These are just for show, our actual number plates are in regulation
