Go to Post quick everyone find everything in the whole world that sells for $125 so we can get an edge on our building 2 days before kick off.....ready...go! - Greg Needel [more]
Unread 13-02-2015, 15:58
alipally11 alipally11 is offline
FRC #5631
alipally11 is an unknown quantity at this point
Are we allowed to use old hard drives as counterweights to stabilise our robot?
Hello, so we had some e-waste and we have some old hard drives that we duct taped together, it basically looks like a black brick. We also have some old dvd drives that i think we might use. So are we allowed to use a block of hard drives taped together(you can't see them) as weights?
Unread 13-02-2015, 16:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Are we allowed to use old hard drives as counterweights to stabilise our robot?
I doubt it....there is a rule about motors, and you're only allowed to use hard drive motors if they are part of a COTS computer that is installed on your robot.
R18
Unread 13-02-2015, 16:38
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Don't forget about accounting for cost on the BOM
Unread 13-02-2015, 17:36
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
It should not be a problem. While there ARE hard drive motors inside each hard drive, to my understanding of your post none of them are hooked up. R18 applies to hooked up motors.
Unread 13-02-2015, 21:22
R18 The only motors and actuators permitted on 2015 FRC ROBOTS include the following: [table of legal motors omitted for clarity]
Emphasis mine.
Would you mind explaining how you get R18 applying only to hooked up motors from that text, particularly given the bold portions? As an inspector, I'd be quite interested to know that.
Unread 13-02-2015, 21:31
JohnFogarty's Avatar
Trapped under a pile of Mechanums
AKA: @doctorfogarty
Ask on the official FRC Q&A. You're just going to start an argument here on whether it will or will not be considered a motor on the robot. Which no one on this forum has the final say on anyway.
Are those old server hard drives? Those things are HEAVY.
John Fogarty
Unread 13-02-2015, 23:04
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It actually says "COTS computing device". Is a hard drive a computing device? It is usually used as a computer part, it has one or more microcontrollers in it, and it computes things. There's no rule that says it has to be operable. I'd give it the benefit of the doubt at inspection, because there's no clear guidance one way or another. (The Q&A may issue such guidance, in which case my position might change.)
Also, per Q315, if you strip the motor out, the motor is no longer part of the device, and thus the motor rules don't apply any longer.
Unread 13-02-2015, 23:06
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
I'd be concerned about the tape
Unread 16-02-2015, 16:01
And, per Q389, Q315 answers the question.
Unread 16-02-2015, 17:09
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Could the magnets in those hard drives affect any of the other electrical components on the robot?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 17-02-2015, 21:47
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Talking Re: Are we allowed to use old hard drives as counterweights to stabilise our robot?
Too late now?
Head on down to the auto shop and have someone cut off as many of the appropriate lengths of leaf spring as you think you might need. Drill holes for mounting brackets and dangle as low and as far from your elevator as possible. There are also some equally dense but geometrically challenging metal parts in the auto shop. Remember if you cut them they're not COTS.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
